Engine Muffler Tip
Discussion in 'Powertrain' started by filip1noy, May 15, 2005.
    filip1noy Guest
    Muffler Tip
    will this produce a loud exhaust noise? http://www.cardomain.com/item/RACT834
    I want a little exhaust tip that will produce a exhaust noise that would fit my toyota rolla 01 and thats under 50 dollars any suggestions where to buy?
    LowRolla Will work for turbo
    Oviedo, FL (orlando)
    a tip won't change the sound of your exhaust at all. that's strictly for looks. you have to change the muffler to get different sound from it. Plenty of cheap universal flow-through mufflers can be found on ebay... but cheap = cheap... they're probably going to sound lousy.
    red 03 corolla s Guest
    i had an "apex" muffler on my subaru that i bought off ebay, cheap rip off of "apex'i" but it still sounded nasty, i guess it depends on what type of car you have...cant beat a 2.5L 165hp motor to produce a nice burly race noise
    filip1noy Guest
    yeye Guest
    Unless you have a V8, tips won't change sound. I know the Marauder tips will change the tone VERY slightly if added on a Crown Vic... And those run about $100 or so each!
    BTW whats the obsession with the exhaust noise? Just by a cheap ebay muffler. Ill save you the hassle, here
    http://cgi.ebay.com/ebaymotors/ws/e...&category=33636
    nomorevtec Guest
    my suggestion would be to save your money and get a trd muffler. not to loud and dosen't sound ricey only draw back is the $$. I been told that its good for 2hp
    kudkudniyog Guest
    I took out the original muffler way back and have the exhaust shop install one of these. http://store.summitracing.com/large...art=PSM-95-9904
    you can get it at www.summitracing.com for $40.00 plus shipping.
    Sounds good by itself, nothing like cheap fart cans.
    kudkudniyog Guest
    <br />
    BTW, get the resonated ones. It MUST be resonated.
    filip1noy Guest
    i should of got that exhaust instead i bought a 20 dollar resonated pilot motorsports exhaust tip at pepboys.
