Engine Motor wont stop
Discussion in 'Powertrain' started by darkgamer1912, Nov 22, 2009.
    darkgamer1912 Member
    CT USA
    Motor wont stop
    Hi everyone my dad got a 98 rolla and its been fine till today when the motor wouldnt shut off. we cant really figure out what is keeping it moving. When we take the key out everything else shuts off the fans and everything inside shuts off but the motor keeps going. the only way to stop it is to pull the EFI relay in the engine compartment. then it stops cuz im kill the injectors. i tried replacing that relay with my own from my 01 and same thing still wont die. any help would be nice
    Rincon , Puerto Rico
    WOw ... Thats a first ... good luck with that unless some how your fuel pump isnt shutting off thats the only reason I can think of :)
    check the ignition?
    Edwin562 SWAG MASTER
    562 SoCal
    98 180sx
    yeah check if u got some sort of short or something... or a relay stuck open... idk i would start checkin all electrical then fuel...
    KrypticKarma ~2001 Corrizm~
    Oshkosh WI
    My accord diesels every so often. I have to let out the clutch to kill the car. But its carbureted with a million vaccum hoses that are 20 years old so something is probably leaking. Anyways im not really sure if fuel injected vehicles can do it. But definately let us know if you figure out the problem.
    CT USA
    yah i talked to my neighbor who is was a toyota mechanic for years he said there might be a short in the igintion so were gonna check it once it stops raining.
    562 SoCal
    98 180sx
    keep updating
    irishricer New Member
    with diesels if the fule pump doesnt shut off it will keep on pumping and wont turn off,its a small solenoid in the pump that sticks open(or closed,dont remember) if its a petrol car id say its ignition fault
    if it's a manual you can always put it in gear, hold the brakes and drop the clutch
    CT USA
    nah its an automatic but i still havent had time to look at it with school and now thanksgiving so it will will have to wait till after friday
    562 SoCal
    98 180sx
    idk but i have a strong feeling its something eletrical, like a solenoid is stuck open.. i would check all relays and solenoid if u can...
