Engine Mechanical or Electrical oil pressure gauge
Discussion in 'Powertrain' started by kudkudniyog, May 31, 2006.
    kudkudniyog Guest
    Which would you guys recommend, mechanical or electrical oil pressure gauge? I looked at autometer gauges and there is a significant price difference between the two. Does the price difference justify the advantage?
    monkey4005 New Member
    electreical no doubt, its better to run a wire into the car than an oil line....
    Vamp Gunmetal 2001 Corolla S
    Rosedale, MD
    Gunmetal Grey 2001 Corolla S
    I'm actually considering switching to mechanical because my electrical one keeps giving me weird and inconsistent readings.
    kudkudniyog Guest
    Does an inline "automatic shut-off valve" exist for an oil pressure line so when there's a break or leak it will block the oil flow. I think in gas(propane) there is such a thing. Or maybe not?
    mechanical is usually more accurate, I hear about sending units on cheaper gauges fouling up after a while. I have a mechanical autometer oil press gauge ($35), never had a problem using the cheapass nylon tubing that came with it but I put it inside a length of clear tubing (like looming elec wires) just incase.
    But yea some alternatives are to use steel braded line (really expensive) or use a gauge isolator
    http://hp.autometer.com/instructions/005282_instruction.pdf#search='5282%20installation%20autometer'
    enjoy
    kudkudniyog Guest
    Gauge isolator? That sounds good. Where do you get them?
    kudkudniyog Guest
    I found it in summit racing. $95.00 expensive
