Max Sec Width Tires on stock rims
Discussion in 'Stop, Drop & Roll' started by macaddict, Nov 1, 2004.
    macaddict Guest
    Hi All,
    I am doing some research on new tires for my 04 LE. I would like to go with BFGoodrich Traction T/A H tires. :D
    I have noticed that the Section Width of the stock tires (195/65R15) is 7.9 inches.
    I figured that I could go a little wider than that; so I looked at the stock tires of the 05 XRS (195/55R16) and it s also 7.9 inches. :shock:
    I was wondering if someone has gone with tires that have a wider section width than 7.9 and if you have had any problems (rubbing, etc).
    Your help is greatly appreciate it.
    I would like to go with a 205/60R15 (section width = 8.2 inches) or with 215/60R15 (section width = 8.7 inches)
    MacAddict
    [TRD]Rolla Guest
    215/60/15 is the widest u can go..i know someone has yoko avs es100 in that size on stock rims
