Engine "Magnetic Fuel Savers"
Discussion in 'Powertrain' started by moises95rolla, Mar 17, 2006.
    moises95rolla Guest
    have you guys heard of them magnetic fuel savers????? its soposed to give you better mpg because it ionizes the fuel so it can burn better. sounds like a gimmick to me but i want to see if any of you guys actualy tried it
    its probaly like the tornado crap
    igorien2k New Member
    it is a gimmick in terms of how it works but it does help mpg for about 100 miles until the computer adjusts
    sonsofwisdom I can fix it
    Austin area
    doesn't work from the start or finish...myth busters tested...
    Also things that don't work...
    Gas pill
    (solid 'pill' dropped into gas tank that is supposed to enhance fuel milage) after adding this...one of our customers had to change his fuel filter...clogged...he did this two more times...each time being told not to put the 'pill' in...if it clogs the fuel filter...it'll clog your injectos...also busted
    The tornado...installs into intake tubing.
    Actually restricts air flow, does not increase fuel economy...mythbusters
    many other various devices like that...they're all gimicks...only fuel saver is letting of the throttle...or getting a prius :D
    moises95rolla Guest
    thanks everone.
    what is a prius and what do you mean letting of the throttle sorry but im a newb dont know much of the terms
    thanks in advance
    dare2drvfast Guest
    throttle=gas
    monkey4005 New Member
    a prius is a hybrid car wich = better mpg. letting off the throttle, is let of the gas and slow down.
    rolla96dx New Member
    that whole magnetic gas savers gimmic has been around since the days of the muscle cars. it didn't work in the 70's, and still isn't working in the new millenia. Unless the change the content of gasoline somehow...
    admayen Guest
    Scam!!! Look up EPA and you might find some stuff on tests done on these type of "gimmicks".
    rolla02 Corollalcholic
    Delaware
    This is what I say to all of those "fuel savers" HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA HAHAH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    If you want better MPG lay off the gas and take it easy on the brakes, but then we do drive corollas my 02 has 106K on it with a automatic tranny and I still get 30 mpg daily and if I drive the highway I can get up to 40+ MPG.
    My cars modded as simple.
    Injen intake
    2.25 Cat-back with a glass-pack muffler for resonator and a TRD muffler
    17X7 inch rims running a 205/40/17
    Lowered 1.75 front and 1.5 rear
    BLOWN struts and a bent lower contol arm on the passenger side only
    94 rolla Guest
    get a better intake. (more flow). thats about the only way to get better gas mileage. or do weight reductions
