Engine Magnaflow or Borla
Discussion in 'Powertrain' started by ph0bi4, Jun 8, 2004.
    ph0bi4 Guest
    Magnaflow or Borla
    Which is gonna be the best quality upgrade. I'm looking for sound, and as much performance as I can get.
    APC_MATRIX_ Guest
    Magnaflow is better cause it's an actual "cat-back" instead of the Borla "axle-back" unit :wink: .
    w1ngzer0 Guest
    but couldn't you use an axle back with the mid pipe people are buying? :?
    APC_MATRIX_ Guest
    Yes, you can use an axle-back with the JP midpipe no problems :wink:
    w1ngzer0 Guest
    im trying to understand at that point. Wouldn't it get rid of any stock piping so you could use an axle back like the borla? or TRD
    APC_MATRIX_ Guest
    Yes, it's a direct bolt in. That flange stays in the exact same spot as stock :wink:
    alpha-vvti Member
    i would go for magnaflow if u want performance
    however i think trd sounds deeper, but just the sound though lol
    w1ngzer0 Guest
    cool. i vote borla since trd isn't up there. Can't wait to be a TRD whore :roll:
    APC_MATRIX_ Guest
    A borla axle-back and the JP midpipe would give you way more gains then the Magnaflow too :twisted:
    Nice choice :wink:
    downey180 Guest
    what midpipe is this?
    APC_MATRIX_ Guest
    JP and he can use an axle-back with it, works fine.
    ph0bi4 Guest
    my pockets aren't deep enough for TRD
    APC_MATRIX_ Guest
    TRD just makes an axle-back and I'd get Borla over TRD any day :wink:
    Schoat333 New Member
    yea but look at the price you spend for those other exhaust systems and then look what magnaflow give you for 300 bucks.... you just cant beat the deal there guys.
