Engine Magnaflow cat
Discussion in 'Powertrain' started by Fgca_rolla, Jul 19, 2006.
    Fgca_rolla milky cocopuffs
    Fort Myers, FL
    Magnaflow cat
    Well I'm about to order the magnaflow high flow cat and well I only have one real important question about it. Will the OBII sensor have enough slack in the wiring to make it to the OBII bung?
    Heres the link to the cats:
    http://www.ptuning.com/html/Item-De...e=model&ModelYear=All&ModelDesc=Universal Fit
    Will it fit fine? Does one look better than the other? I can't quite figure out the difference other than one is shinney. Lol
    Its for a 9thgen too. Thanks.
    Also looks like the SS version loses the O2 bung on the end - hard to tell from the pic and it is not indicated in the description. Not sure how much difference there is between a 9th gen Corolla and a Matrix - but I know on the Matrix, it is pretty tight there (might be doable, but your going to have to pull the wiring to it - messes up the clean looking bottom).
    Fort Myers, FL
    I'm imagin it would be similar. I really don't care what under the car looks like well, honestly, cuz I never see it.
    Thanks though.
