Engine MAF sensor doesnt fit
Discussion in 'Powertrain' started by sxlostv1, Aug 20, 2004.
    sxlostv1 New Member
    Los Angeles
    I have this intake made by Bomz racing and my MAF sensor doesnt fit inside the MAF slot. The screw holes are off by a bit. Does anyone know how to fix this?
    Fox New Member
    Under your sink.
    i got the same intake and had no problems with the maf sensor port... bestcarpart is a pretty good seller... you could try and get another intake.. your's is probbaly just a little factory offset
    sxlostv1 New Member
    Los Angeles
    it's ok... i found a solution...
    i just rotated the maf sensor a bit then i used a 3 inch metal hose clamp and just clamped it onto the intake pipe./ thanks anyway fox
    System Error Guest
    ghetto
    blancokracker Guest
    lol lots of maf sensors don't fit
