Lug pattern!
Discussion in 'General Discussion' started by JFREE55, Feb 8, 2005.
    JFREE55 Guest
    Lug pattern!
    does any one know the lug pattern and the off set for the 03 corolla S it will be 18's
    jdmmarkii Guest
    5x100. i'm not sure about the offset.
    polo708 New Member
    9thgencorolla.com
    I believe the stock offset is something like +38mm
    anything around 35-45ish should be fine if your tires are sized right.
    SquirrelMaster New Member
    depending on the width of the rim will determine what offset is best.
    is your car lowered? if so, what springs are you using?
    18x7.5 you should go with a +42 offset
    I would recommend nothing lower than +40.
    the lower the number, the more the wheel will stick out
    JFREE55 Guest
    Well I am on air ride suspension!!!! Thanks for the Info
