Lowering Suspension
Discussion in 'Stop, Drop & Roll' started by Crimson, Aug 20, 2005.
    Crimson Guest
    Lowering Suspension
    for a 03 Toyota Corolla what are the best springs to put on it?
    las vegas
    go with groud control coilover so you could adjust your ride height and tokico blue for better performance ride.
    toyotech Guest
    depends on how low you want to go, the spring rate you are looking for, the driving/racing you do. you need to explain what you want before u know what the "best is" some lowering springs will drop the car 2" but have only say 180 spring rate while 1.2" drop springs could be near 300. also you have to take in the choice of new dampers and camber kits for how low you want to go.
    tunerperformance New Member
    florida
    i got a set of the tenzo gfr2 and they are sweet not to stiff or soft nice drop handels very nicely not a big dent in your wallet either especially if you have the hook up on install
