Engine lowering lift
Discussion in 'Powertrain' started by admayen, Aug 19, 2006.
    admayen Guest
    lowering lift
    Is their any way to lower the rpm when lift activates? I think that if their is something like a vtec controller that can adjust that then the XRS will be much quicker. I ask this question because when I race the car and shift, it seems to slow down a bit between shifts until it hits lift again or even raise the rev limt for that matter. Any ideas?
    sxlostv1 New Member
    Los Angeles
    you can control valve timing but not lift (power enterprise Camcon). theres not too many vvtli guys here, try newcelica.org or 9thgencorolla.net.
    admayen Guest
    Thanks. I'll look at that site in more detail.
    HaPpYfAcE New Member
    Tucson, AZ
    someone i know with a celica gts actually bounces it off the rev limiter in 1st gear so he lands in lift in 2nd. i'm in no way suggesting that you should do this to your car, as i've also heard from corolla xrs owners that it's possible to land in lift w/o having to do this.
    admayen Guest
    How is that possible? I've quick shifted and power shifted. How else can you stay in lift?
    Tucson, AZ
    got me...i just know that i've heard that from others that had gotten their xrs recently.
    here's a video that i remember being posted when someone on one of these boards had gotten their xrs and it was pretty new still...
    http://videos.streetfire.net/search...18111125f39.htm
    jtweezy New Member
    Irving, TX
    admayen Guest
