Low Oil Pressure light...
Discussion in 'Care & Maintenance' started by MovieSTAR, Mar 3, 2009.
    came on tonight. added 3 quarts of oil because i was down. think my car is mad burning and i have a P0420 code. changed the o2 sensors. next setp catalytic conerter?
    nyrican52884 Active Member
    Plymouth, MA
    If the engine is burning alot of oil you will go through catalytic converters an O2 sensors fairly quickly
    wow burning that much oil try maybe a 5W-40 if it exists? or 10W-40 to try to keep it from slipping out so easily
    shouldve been more clear. I changed the O2 sensors to get rid of the P0420...and it didnt. so is the next step to replace the cat? i bought 10w-30 tonight. normally use 5w-30. my mechanic friend recommend that. if it doesnt work ill try some 10-40.
    if you remember i have black shit coming out my exhaust? perhaps that burning oil as i thought before?
    Ares Active Member
    Houston TX
    ^ I remember that, and it puked in the driveway/floor right? hmm... how fast do you burn oil?
    it was in the snow actually. umm...i put oil in 1500 miles ago when i changed my oil.
    all I can suggest is fill up the oil every 400 miles or so and check the gas :D
    Ares Active Member
    Houston TX
    the gas? I remembered before my water pump and the seals were changed, i used to burn oil around 1/4 of the dipstick before change oil. so far, after the water pump and timing belt change, i have not notice any significant oil sipping.
    Holy crap... 3 qts of oil and you just changed it 1500 ago!?
    Changing your cat will get rid of the code, but you'll still be burning oil. It's time for new rings.
    blegh tell me about it
    time to swap in a new block
    tell e about it.
    im fskin broke.
    las vegas
    +1 w/low miles
    rayray1 Active Member
    try using German Castrol Syntec 0w30 first (says Made in Germany on the back).... it runs heavy for a 30-weight oil, almost a 40 weight.
