Engine LOW BOOST ON TRD S/C HELP
Discussion in 'Powertrain' started by truonghai, May 24, 2004.
    truonghai Guest
    Hey did anyone have problems with the TRD s/c running low boost.
    I got it dyno tuned and it's only running 3psi. WTF?
    The belt is tight what on earth could be wrong.
    I have a UNi chipped system as well.
    brownbanana ToadMotorSports
    Oahu, Hawaii
    gave you a link on matrix owners which had people with the same problem. hope that helped...
    tom Guest
    What is the link anyways? I'm curious myself on how to fix that problem.
    RexPelagi VDub
    Canton, Ohio.
    i Thought they were running 6 psi or so stock? are all at 3 or is this just a bug?
    hooolala Guest
    Re: LOW BOOST ON TRD S/C HELP
    3psi?? lol... my was dyno at 8psi..
    you might want to check your vacume line (sp?) to see if it's plug correctly or to see if there is any leak...
    also is the unichip you got already tuned?? if not, you might want the place that dyno tune unichip to turn up the boost
    Oahu, Hawaii
    RexPelagi VDub
    Canton, Ohio.
    O so not all the s/c's dyno like that? ok i thought maybe they all were that low for some reason.
    truonghai Guest
    Yeah my Unichip is tuned at 3psi, It's a mechanical problem, hmms i am waiting for a reply.
    bummer this. Thanks for the help all.
    Does anything seem to be wrong? i don't know and no one here knows.
    Oahu, Hawaii
    did the people at matrix owners help you out any?
