Engine lotus elise 1zz-fe engine swap into corolla?
Discussion in 'Powertrain' started by trdracing2005, Sep 1, 2006.
    trdracing2005 New Member
    Portsmouth, virginia
    1) it's not 1ZZ, its a 2ZZ get your engines right. :)
    2) it's possible, but however unlikely for you to do such a thing without some expert help and deep deep deeeeeeeeep pockets
    3) you can't do it with just the motor, good luck tryin if you do - we'll sit back and giggle
    in order to take upon such a project, you will need to take a look at the nightmare that is hellish mantis - if you can duplicate it *ON YOUR OWN* you will have my respect, until then... don't say ' im droppin this motor in ' and expect that to actually fly. do some research.
    in addtion to the motor expect to spend about 7k or more to make this work...
    Des Plaines, IL
    x2. You wont get far with that motor alone. Look for clips or salvaged vehicles. The motor will fit as its in the hellish mantis which is one sick ass rolla. You will need tons and tons of help.
    Cuztomrollaz98 MAD VLAD!
    Littleton, CO.
    It took doc quite a bit of work and time to get that done, hellish mantis was one hell of a project
    reason I need new motor is because I ran into a 4 foot water flood, didnt mess up anything at all no water in interior, just had to hop out the window to push it out lol. I was pissed. my engine starts it just sounds like a car with about 2 billion peices of metal in the motor smackin the pistons =( it was raining so hard I couldnt see the puddle at 10 mph.... typical Virginia
    Des Plaines, IL
    First and foremost find someone that will swap the engine for you. Then begin to look for a new motor. Try to find a 2zz from a salvaged car so you can get all the parts you need right off the car.
    jtweezy New Member
    Irving, TX
    this 2zz is special tho!!
    DeebsTundra Big Tires :)
    Near VoRtEx
    Ok, just out of curiosity...why a 2? They are going to be alot harder to find than a 1. You'll be out WAAAAY more money to do a swap...just to gain a VVTL-i motor. If you want power, you would be so much smarter to boost a 1zz. Look at Vortex. He's got a 1, which off the top of my head stock only has about 35-40 horsepower less than the 2. ...running 14 pounds of boost he's somewhere over 260. ...for far less money than the time it would take for you to put a 2 into your car.
    Not trying to sound mean, but it's like my boss always says. Work smarter, not harder. And dropping a 2z into your car, is going to be a hell of a lot harder than boosting the 1z.
    true =) I have a non vvt-i I may just buy someones vvt-i 1zzfe.
    SaberJ2X Lurk MOAR
    Mayawest, PR
    actually I'm very happy with my non-vvti, no MAF
    that will still require you to do the following:
    a) change out your entire wiring harness
    b) change out your ECU
    c) change out your injectors
    Barnacules 100101101011011
    Duvall, WA
    Wouldn't you also need custom axles and shit?
    Littleton, CO.
    The 1zz-fe are strong motors, I'd boost that instead of spending 10k+ on a swap
    laz Member
    NYC
    I gotta get a new motor tho
    my motor is done. what non vvt-i motor should I get? I can spend up to 2000 dollars
    you can pick up any non vvt-i motor... if you can spend up to 2000 this is what i'd suggest... rebuild the one you've got. :) if your block is blown to shit, then you've got a couple options:
    1) new short block from toyota is 1300+shipping (thats just the short block or bottom end)
    2) get a long block that is in good shape but needs rebuild, i've got one i'll sell ya for $450 shipped or you can pick one up in a junkyard hopefully (long block is head and block)
    if you get a block (from me or somewhere else, junkyard or whatever) these are your options:
    1) rebuild stock -> ~$800 for a master rebuild kit + whatever assembly charges are at a local machine shop... typically about $400-500 bucks
    2) rebuild built -> ~$???? (depends on what route you want to go) + $400-500 bucks assembly charges
    realistically, i'd pool as many resources as possible and see if you could just build up the bottom end of a motor, then you can work on the top end later.
    I gotta find out insurances funding. they are reinbursing me my money back after I get my engine fixed/rebuilt im not getting a new engine I found out today. I need the engine rebuilt. I would like to rebuild for performance, im not going to boost the car so im going for a n/a setup
    Des Plaines, IL
    a n/a setup?
    insurance may total my car, if not replace engine, ecu, wiring, and carpet
    01rollas New Member
    well i got two blown engines sittin' in my garage one is vvt-i and the is non-vvt-i and the third engine is stiing inside. i was gonna to put the 2 but yep they are right it is more expensive to install overall . the new 1zz it has right now is sweet with only 1020 miles on it. Japan here i come!hehe
