Lotus announces first Evora race edition, Type 124 endurance car
Discussion in 'Auto News' started by Autoblog, Sep 11, 2009.
    Autoblog Guest
    Filed under: Motorsports, Coupe, Performance, Lotus
    Lotus Evora Type 124 - click above for high-res image gallery
    It's only been a week since Lotus delivered the first production Evora to a customer, and now the sports car maker has unveiled the first race-ready version of its newest model. The new Type 124 Evora is built to FIA GT racing specs and will debut next year at the Nürburgring 24 Hour race.
    The Evora already has many of the basic elements needed to make a robust race car thanks to its bonded aluminum structure and mid-engine layout. But the racing version receives a revised version of the stock car's Toyota V6 cranking out over 400 horsepower, along with a new paddleshift sequential six-speed gearbox.
    Even with a full roll cage and fire extinguisher system installed, the Type 124 gains about 440 lbs of "lightness" dropping the car to about 2,600 pounds. How'd that happen? Lotus has replaced the standard bodywork with lightweight composite and carbon panels that add front splitter and rear diffuser elements, along with a prominent rear wing.
    That rear wing will push on a tweaked suspension system (both the four-way adjustable dampers and the anti-roll bars are tunable) and the car will run on wider 18-inch Pirelli slicks. Braking will be provided by a Bosch ABS system optimized for competition and a set of six-piston AP Racing calipers.
    Lotus says it will support a factory team in 2010 and 2011 and presumably offer customer cars as well. Want to learn more? Check out the official press release after the jump and the high-res gallery below.
    Gallery: Lotus Evora Type 124 Endurance racecar
    [IMG][IMG][IMG][IMG][IMG]
    [Source: Lotus]
    Continue reading Lotus announces first Evora race edition, Type 124 endurance car
    Lotus announces first Evora race edition, Type 124 endurance car originally appeared on Autoblog on Fri, 11 Sep 2009 10:00:00 EST. Please see our terms for use of feeds.
    Permalink | Email this | Comments
    More...
    Ares Active Member
    Houston TX
    I guess with enough money, the camry's V6 could actually be a racecar's engine...
    las vegas
    i love the whole looks
