License Plate Lites?
Discussion in 'Exterior' started by dominator, Dec 13, 2003.
    dominator 04 Rolla 5spd.
    Has anyone ever replaced the rear license plate lites? How is it done? The owner's manual warns against trying to avoid damaging the car!?
    koni9 Guest
    1. Open the Trunk 2. Unscrew the inner door lever(yellow) Snap off the black matting. They are just snap pins so be careful. Once that is off you should have clear access to the lights. Reach up, twist and pull them out.
    Hope this helps
    :p
    Right on... Thanks koni9. Have you replaced yours? I wonder if any LED bulb (license, tail or brake lights) could be used at all on the Corolla without blowing fuses?
    noservice2001 Guest
    i have green LEDs for my rear plate light... no fuses get blown... uber easy to do....
