LED lights
Discussion in 'Exterior' started by patrol48, Jan 2, 2008.
    patrol48 Guest
    LED lights
    I have an 06 XRS and was wondering if anyone has installed LED tail lights? I see some on EBAY for 125.00 & shipping. thks jim
    i've installed it once and put the regular one back. i dont like the fast flicker
    you just have to install a relay to avoid the fast clicker..
    Rincon , Puerto Rico
    How do you make the turn lights flash quicker ????????
    Well, most cars use a thermal blinker circuit for the signaling so when the resistance load in the system is reduced(LED bulb) or missing(burnt bulb), all(or remaining) bulbs will flash much faster to compensate for the extra power running through the circuit. A thermal blinker uses a bi-metallic element, which responds to heat. It takes advantage of the fact that heating an object makes it expand, and that different materials expand at different rates. Of course, you can always buy a thermal circuit that blinks faster naturally even when you have the normal required load in the system. I wouldn't recommend that though since it's considered ricy and attracts the cops.
    the 9th gen aftermarket LED taillights are only the brake lights, the signals and reverse retains the standard incandescent bulb.
    JordanInc ZZE110
    i just bought mine at v-leds.com
    Nice signature ..... You should make one for every one ....LMAO
    JordanInc ZZE110
    Yea................LMAO
