KYB Struts and new OEM springs
Discussion in 'Stop, Drop & Roll' started by ghoztrider, Feb 17, 2005.
    ghoztrider New Member
    Suburb of Philadelphia, PA
    I need my suspension upgraded. Can i put OEM springs and new KYB GR-2 gas shocks?
    I don't want to lower my car and non OEM springs lower my car
    uh...why not? my car sat on stock springs with Tokicos for a good 7 months before i dropped the front end...still have to do the back.
    I read that oem springs have a lower bounce number or sometin and if u put after market struts on that the struts will wear out really quick.
    If i lower my car it will make me bottem out even more. Plus i got a trd muffler so the tip will scrape on dips and stuff
    the tip scrapes only if you don't drive carefully...and you can get Eibach springs that don't drop the car too much.
    hell...my Intrax springs have the car at a good height...i don't scrape anything. then again, you have to drive at a slant down certain hills and over speedbumps...but that's nothing major.
    by the way...i know nothing about them wearing out your struts more...i know if you lower the car on STOCK struts, they'll wear out...but struts that are meant to handle lowering can be left at stock height with no problem.
    JLee TD05 3SGTE
    NH
    I have the Intrax/Tokico drop as well. I only have to be careful around steep driveways and huge speed bumps..it's not at all a problem as a daily driver.
    I'm not sure if I ever scraped my tip..maybe once or twice..
    teevee247 Well-Known Member
    Montreal, QC
    ghoztrider, you have it backwards... Putting aftermarket struts on stock springs is fine, but putting aftermarket springs on stock struts will wear our the stock struts... If my lowering springs don't come in soon (been over 8 weeks now since I ordered them), I am cancelling it and putting my Tokico's on my stock springs
    JLee TD05 3SGTE
    NH
    Where'd you order from? 8 weeks is unacceptable..
    Cape Coral, FLorida
    yea unless these things are comin from overseas the slowest possible way, i think u got screwed over
    Montreal, QC
    Yeah, im cancelling next week if they aren't in yet... I ordered from a local performance shop, figured i'd support local business... well, they got their chance and lost it...
