Koni and Skunk 2 susp.....
Discussion in 'Stop, Drop & Roll' started by chino_h80, Feb 4, 2005.
    chino_h80 Guest
    I currently have skunk 2 coil overs and would like to get Koni adjustables. Will the coil overs fit on the koni strut tower design? If not is thier heavy modification to make it work? is thier another strut i don't know about that you guys know about? I don't want the Tein or any thing else coil over set for 1 billion dollars. Does any body have this set-up (Koni struts and coil overs)? Thanks
    KingKuei Guest
    I have the Konis. for the front, the Koni shocks are actually inserts. You cut off the top of the stock struts, take out the parts inside, then drop the Konis in place of them. And for the rear, the Konis replace the entire strut assembly. I don't know how the Skunk 2 coilovers are, but if you are already running them in conjunction with the stock equipment, then there's no reason why it won't work.
    chino_h80 Guest
    Some aone please give me more information on the konis. Every one tells me the rears bolt right on but the front need modifications . Can some one please give me a little more detail? And is it hard to do? thanks
