Kill Switch
Discussion in 'Interior' started by ctsire13, 2004年04月03日.
    ctsire13 Guest
    Kill Switch
    I want to install a kill switch...Anyone know which sensors can be used to create a kill switch on? I don't want to do the starter, that is way to common and obvious.
    crucial Guest
    i heard a good idea to do the fuel system, so that you could cut the power to the fuel pump or something then the car would start but get about a block and then quit and the thief would give up. don't know where to put it though.
    Sasuke Guest
    it hink u can wire it to under seat or uder the dash where steering wheel at
    zhentipede Guest
    how bout those plastic/key things they put on jeeps?
    your ignition keys should be in and the plastic thingy also on a seperate inlet...... its just a thought i read it somewhere...
    crucial Guest
    best idea ever= disconnecting the 4 ways and wireing it there
