Engine Just ordered headers, how to install??
Discussion in 'Powertrain' started by imported_corollas, May 21, 2004.
    imported_corollas Guest
    hey i just ordered some of those headers off ebay and iam wondering if anyone has a link to how to put them on , or if they can tell me how, and how long, what u need, and so on,
    thanks
    i cant wait :shock: :D
    I haven't removed them on a rolla, but on another car it involved welding the new headers to the exhaust system and buying new bolts for the headers to connect to the block. Maybe the corolla is easier to work on?
    RollaS New Member
    it won't require welding.......i think you'll need a new gasket though.
    RexPelagi VDub
    Canton, Ohio.
    Hey when you do this can you take pics? Id like to see the process as well.
    KingKuei Guest
    Ya, getting a new gasket minimizes the chance of leaks. Maybe even some new nuts and studs on hand just in case you strip something. No welding is required, but you'll have to work from both above AND below the car to get to all the nuts and bolts necessary to remove the heatshiled and header.
    CarbonB New Member
    Just get some sealant and a new header gasket kit.
    You remove the old headers from the engine just replace the gaskets, connect it back up and that's it.
    There was DIY on a matrix site I think :p
    oh yeah ill def take pics
    but should it come w/ a gasket or should i order one because its gonna be here tomrow :D :D
    hooolala Guest
    installation is pretty easy. the only hard part is taking off the heat shield and the stock header. there is the step.
    1 ) Unplug the O2 sensor from the engine (a little connector on the top right side of the engine)
    2 ) Unscrew and take out your top heat shield
    3 ) Unscrew your bottom heat shield, (the bottom heat shield will not come off)
    4 ) Unscrew your header from the head block. (besure to do it in a pattern)
    5 ) Unscrew your header from the exhaust pipe.
    6 ) Take the stock header out from the engine bay.
    7 ) Unscrew your O2 sensor from the stock header and screw it to the new header
    8 ) **IMPORTANT**Take the stock exhaust donut from the header (see picture below) and put it onto the new header.
    9) put the stock gasket back to the right place
    10) screw your new header.
    11) done.
    NOTE1 you don't need to change the gasket because our gasket is reusable.
    NOTE2 besure to Spray the exhaust studs with some WD-40 or other lubricant
    NOTE3 there are 80% of chance your header will leak from the exhaust donut
    hooolala Guest
    btw.. here is some picture i took when my ncfour friend help me install my header..
    wow! looks like a formal DIY write up to me! can I add that DIY to my site?
    hooolala Guest
    sure.. but you might want to check on google or yahoo.. they have full instructions.
    just type in "how to install the header" and you will find few of them
    should u replace the donut then?
    how can u stop it from leakin
    whoooooooo ho i got em in iam gonna pu them in right now and drive and take some pics, yeh ha :D
    cya!!!!!11 :D
    Blk03Corolla Guest
    So Hoolala you never mentioned how big of a difference you felt with the headers compared to the stock header.
    just got done, its sooooooooo bad, u can hear the engine alot more and u can feel a difference, not a huge one but u definatly can, i freakin love it :D :D !!!!!!
    alpha-vvti Member
    that means its ALOT louder even the engine is NA? lol
    APC_MATRIX_ Guest
    Nice "how-to", this is going into the bookmarked section :wink:
    Anyone know the proper TQ to put the nuts at on the header?
    RollaS New Member
    27 ft/lbs
    APC_MATRIX_ Guest
    Thank you, I'll need that next week when my JP headers come in :twisted:
    RollaS New Member
    no problem.......i've got the whole matrix repair manual on my computer, so i can pretty much look anything up.
    okey then , what the wiring diagram for the powere mirrors , like which color is ground and what not, aslo same thing for the front amber blinkers, which color wire is grond and which is hot when the blinker is on
    i just got some power M3 mirros w/ blinkers so ima hooking them up today
    thanks:D
    RollaS New Member
    check corollatoys.org the 2004 corolla manual is on their. my acrobat reader is acting up.
    methaneb Guest
    RollaS you really know what to do with those nuts. you know all about nuts 8)
    APC_MATRIX_ Guest
    Going to install my JP headers tomorrow :twisted:
    alpha-vvti Member
    let us know how it sounds and how it performs afterwards =D
    APC_MATRIX_ Guest
    Not a problem. I wouldn't be surprised to see a slight loss in low TQ though (say 5 ft-lbs), but I think that the gains up high will be worth it since that's where I race anyways.
    Got to eat than I'm going to go install it and take hella pics of it so I can do a formal "how to" on it :wink:
    APC_MATRIX_ Guest
    Didn't take hella pics cause it's a very easy install.
    As for that, it sounds like s*** cause I have a huge leak where the donught thing bolts up to the stock midpipe. They are at different angles, so there is really nothing I can do about it. Performance seems to be the same if not a little more throttle response (haven't really driven it yet though).
    I am getting a custom midpipe made with my first couple paychecks, so that should solve all of the problems and I'll have my exhaust guy check out the headers for leaks too (just in case).
    Overall I'm frustrated that I have a leak (a big one at that), but I half expected one. I am now just waiting to get payed so that I can get my midpipe done and be done with my whole exhaust system :twisted:
    where did u get ures?
    mine had no problem?
    APC_MATRIX_ Guest
    JP. It's not the headers problem, they are great. It's just that the midpipe and header come together at a different angle so the bottom of it leaks a lot. Not a big deal considering I don't drive my car right now cause I screwed up the windows :?
    The problem will be fixed for sure when I get my midpipe.
