Engine Just a question about a clutch.
Discussion in 'Powertrain' started by Mike4831, Sep 11, 2004.
    Mike4831 C-Town Pimp
    Statesboro, GA
    Today when i was driving around (my car has been sitting for 5 days.) i noticed that my clutch pedal felt like there was like a bump. and when it did it a couple times the car would either jump into gear, or it would like hesitate.
    i have called a couple friends at honda. i check my fluid and its fine. i check all the vacuum lines and there all connected. i am trying to find a honda dealership around here but with no luck.
    my car is under warrenty till dec of 2005 so i am not too concered about it too much. just a lil wierd.
    Statesboro, GA
    well it happend a couple of times.
    well the clutch in my old corolla last 40k miles so that was kind of bad.
    RollaPete Guest
    Get yourself a Toyota again ... makes all the difference :p
    Was too tempting ;)
    RollaPete Guest
    Didn't mean it as an attack buddy, just humour ;) My clutch is starting to go bad at 50k so ... nuff said!
    Take care, hope you figure that problem ;)
    TurboRolla21 Guest
    Get a new one! I love aftermarket clutches! They = FUN!
    SkyAce2004 New Member
    i need a new clutch also, hit 40k a couple days back, and its slipin, but if ima get a new clutch, im getin a flywheel to go with it
    Statesboro, GA
    i really wont know till christmas but hopefully it wont cost alot. since it happened a couple of times i wont worry about it.
    Brooks2741 Guest
    The gears grind for an instant when I downshift from 4th to 3rd. That is with the clutch to the floor. When I make the shift slowly it doesn't grind but quick shifts grind. I am assuming I will need a new clutch before I do some damage to the synchros and gears. What company makes a good aftermarket clutch? I am looking to turbocharge in the near future so I would like to get a heavy clutch before that. Thanks.
    Brooks
    CadetLee Guest
    Sounds like your synchros are starting to go -- replacing the clutch probably won't fix it. Mine occasionally grinds (very, very briefly) on a fast shift from first to second, but not usually..
    I have an ACT clutch (heavy duty pressure plate and organic disk), and I'm very happy with it. It hasn't overheated or slipped on me yet..
    slvr2000fdvspec Guest
    sounds more like synchros than clutch
