Engine IS300 2JZGE block
Discussion in 'Powertrain' started by whydontyouchoos, Mar 24, 2009.
    whydontyouchoos KFM
    Phoenix, Arizona
    IS300 2JZGE block
    ive been reading a little into the IS300 i am buying this summer, and im really interested into building my block into the supras 2JZGTE
    I know the head is defferent and the cams too, but how much is actually different between the two blocks anyone with 2JZ expirience?
    las vegas
    dont know much but if you talking about n/a supra or tt?if you talking n/a i think there the same block but tt its obvious beefed up internals.i know some of is300 owner buy a built short block and upgrade the cams,lifter and retainers.
    rayray1 Active Member
    The IS300 is a solid car... my buddy is also looking into one to replace his Corolla.
    whydontyouchoos KFM
    Phoenix, Arizona
    well im looking to put a single turbo setup on my IS300, im looking to make about 600-650HP, an di know the 2JZGTE from the TT put out 315 just from the block and the 2JZGE non turbo VVT-i from the IS300 only puts down about 215 at the block, i just want to see if this is an engine rebuild i could do myself or if i needed to be changing a lot more of the internals...
