Invincible Toyota
Discussion in 'General Discussion' started by TurismoDreamin, Jan 27, 2006.
    Tulsa, Ok
    Invincible Toyota
    If anyone ever had any doubts about Toyota reliability or durability or even how much punishment a Toyota can take before it dies, this video will make you a believer....
    Its like the energizer bunny...it keeps goin and goin and goin.....and when you think its about to stop.....it goes, lol...
    Click Here
    Cape Coral, FLorida
    toyotas from the 80's and 90's are forces to be wreckoned with. whoever denies this should get smacked
    Denver Rolla 98 impreza
    wow... thats all I have... WOW!
    rolla02 Corollalcholic
    Delaware
    Nothing can stop a Toyota. HAHAHHAAHHA
    JLee TD05 3SGTE
    NH
    sonsofwisdom I can fix it
    Austin area
    well...I can speak to the near godly strength of the 2uz (tundra)...a loobe guy (like how I incorperated noob and lube...yeah...yeah? HA HA...oh sorry) left out a drain plug on a sequiauoorieah...however it's spelt...lady drove it for TWO DAYS in austin traffic with the oil light ON...they had to replace one cam...three pistons...and bearing...didn't throw a rod...
    cam had heat marks on it..same with pistons...block did too so short block was ordered...DIDN'T THROW A ROD...TWO DAYS!!!
    then a tundra came in with two vvt actuator codes...the two guys working on it (not noobs) were bouncing it off the rev limiter..several times...then it started making a knocking sound.
    "uh...you guys check the oil level?" vvt works off of oil press...neither bank worked
    It had 1 quart in it...filled it up with oil...it's been several months...comes in for regular maint...no probs or noises...these two guys get the truck everytime...and check it each time...no probs at all...damn those engines kick ass
    Another guy in the shop used to work for Lexus...he's got some good stories as to the duribility of the UZ-FE series..same tech is in all the toyota engines though
    AE102 New Member
    hehe crazy..
    ghoztrider New Member
    Suburb of Philadelphia, PA
    thats insane, makes me wonder wat my rolla can withstand
    I was actually told by one of our techs at Lexus who used to work only on the 1zz motor and I quote "You have to physically tell this girl that your not going to put oil in her before she starts bitching back at you about not having in it"
    now thats a tough motor ;)
    hehe my car is living proof of the durability of the 1zz. As long as she's got oil, water and enough fuel she's damn near bulletproof. The Colorado crew knows how I drive my car even to the store... hehe like i stole her. :)
    well the motor might be, but not the tranny and everything else....
    and i don't think mine is, even wit fully synthetic oil, and new sparks, i got smoke comin out running 5-6rpms as it shifts and right b4 it shifts.... so idk bout bullet proof, and i odn't run it on redline all the time too
    and thats with the intake on, i don't know if it does it with the stock airbox and K&N air filter
    JLee TD05 3SGTE
    NH
    With 51k, you're having trouble?
    Maybe it hasn't broken in yet. :D
    idk, not sure if thats just how the motor is or what, but its puffing out smoke at high rpms right b4 shifting or right after shift.....
    you running full synth in there??? if you are thats your problem.. its too smooth for our cars and Will cause it to smoke at under 75K (about when our motors are actually fully broken in. just the regular moble 1 is fine to... if thats what you use than you got something else... valve seals maby
    Austin area
    One thing I noticed...actually scared the piss out of me...right after I had to replace a head on a 2zz...those damn things are NOISY...luckily my team leader had a newer one in his stall so I could compare valve train noise.
    Mine was actually a little quieter. Too used to the new 4cyls in the camry. The 2zz is a noisy little fart.
    Hey Denver Rolla...I've never heard of synthetic having that kind of problem...any articles on that? I've heard of the cam seals, crank seals, etc. leaking...but that is solved by replacing the seals...as far as I know synthetic is better because it is smoother...I'de be interested in anything you have dealing with that.
    valve clatter, its a toyota thing, I dunno eather
    DangerousbyDesign New Member
    That was amazing
    JLee TD05 3SGTE
    NH
    I guess that would explain why I had no smoke when I switched to synthetic at about 120k.. :p
    Rolljah nunu
    @ home
    1 word...unbelievable!!
    this video literally had me do this :snap:
    Delaware
    I am running Castrol High Mileage in my 02, yes I have enough miles to run that, and I have not problems with smoking or nothing else.
