Engine Interesting observation...
Discussion in 'Powertrain' started by CorollaULEV, Sep 15, 2005.
    CorollaULEV Guest
    Using Digimoto to capture some sensor data on my '03 Corolla...short term fuel trim has always been ranging around 0 to -5% (varies with O2 sensor input and fluctuates a lot) at idle. Long-term fuel trim verifies this long-standing *SLIGHTLY* rich mixture, as it is around -5% @ idle - been like this for a few months. The ECU is subtracting fuel to compensate for a slighly rich mixture - it's nothing major...+/- 10% is within normal limits...but still the mixture has been slightly rich for a few months.
    I noticed yesterday that my air filter was just horrendously filthy (yeah, that's one maintenance item I don't check as frequently as everything else).
    Anyhow...I went, got a new STP air filter from Autozone, replaced it, drove back home and hooked it up to Digimoto....and guess what, short term fuel trims were ranging from +2-7%, indicating it is now ADDING fuel to compensate for a lean mixture. It was like this throughout the rpm range.
    Numerical evidence that a dirty air filter can make a difference....the ECU is now adding 2-12% more fuel, depending on conditions.
    Trav
    CorollaULEV Guest
    And this morning, I watched my long-term fuel trim jump from -5% to 0. I had the EVAP error codes pop up due to a loose fuel cap - so, after clearing the codes I played around for a bit with the Digimoto and while I was idling the engine, long-term fuel trim jumped from -5 to 0. Cool stuff! The only thing that's different is the new air filter.
    Trav
