Instrument Cluster Swap- Adjustments?
Discussion in '8th Gen' started by MP220, Feb 9, 2015.
    MP220 Well-Known Member
    CT
    2001 Toyota Corolla CE
    I'm going to be buying a gauge cluster from eBay that comes with a tach for my Corolla CE. I know that in order to preserve the same mileage, the speedometer has to be swapped out directly- I'm assuming the rest should be plug and play. But does anyone know if anything else, i.e. the fuel gauge needs manual adjusting? Or will it automatically adjust once it receives power and a signal from the ECU?
