Installing Fog Lights
Discussion in 'Exterior' started by rolla996, Dec 30, 2007.
    rolla996 Guest
    Hey guys,
    So i have a great set of Fog Lights and i defianetly want to buy them and install them myself. But i get confused when the electrical stuff comes into play. I was wondering if anybody knows a great (corolla 8th gen specific) tutorial. I have searched but have not found any.
    JordanInc ZZE110
    i want fog lights too...and i also have an 8th gen thats not 01 or 02
    i have no idea where to put them
    the black space under the grill doesnt seem ideal
    94 rolla Guest
    its really not all that hard. positive to a switch from a power source, meet that with the positive on the fog lights, and then find a ground. not very difficult but if you need it i think autozone sells fog like wiring kits
    rolla996 Guest
    i have a 99, and i think i can mount them nicely on top of that median gap (top of the black gap). But see i don't get the grounding part and the power source.
    Phan Well-Known Member
    Orange County, CA
    hey Jordan when you installed your black JDM headlights, does it fit 100% (i mean from corner to corner, angle to angle) like OEM headlights and corners?
    94 rolla Guest
    power source can come from anywhere. the most obvious one is your battery. just look to see how many volts the fog lights need. if its 12 you can wire straight to the battery. if its less than that then just look for a source on your car that requires the same amount and then tap into that. to ground, just run a cable from the ground point to the chasis of your car
    Nice attempted thread jacking.
    I ran Hella 1152s for a while. I removed the center section of the stock bumper so I had ample room to mount the lights. I just removed the bumper and spaced the fog lights 2 inches from each side of the front plate. I ended up drilling for the mounts. It's not hard, just time consuming to measure and drill exactly where I wanted them. Wiring is very easy. The fog lights you purchase should have a wiring diagram for you to follow. Sometimes, they'll include a relay too. I always wire them directly to the battery, but you have to be careful not to leave them on and end up with a dead battery. You can always play it safe and tap them into the headlight switch so that they come on when your headlights do.
    The basic wiring is composed of:
    Run a wire from the battery through the firewall.
    Run that wire to a switch.
    Connect it to either + or -. It doesn't really matter.
    Run another wire from the other pole of the switch back through the firewall to each of the fog lights.
    Ground each fog light.
    You're done.
    Here's an how mine came out.
    I ended up removing the fogs since there's absolutely no need for them anymore after I installed my 50W HIDs. I couldn't even see the light output from the fog lights anymore. :D
    rolla996 Guest
    i love u'r bumper man, i know u cut the middle gap, but did u have to fill the sides or anything. cause i know the median gap looks thick but i assumed it was just like very thin plastic (paper like) and that it might look bad afterwards. Did you do the same for the top grill to?
    And the only thing i have yet to understand, is what u guys mean by grounding. I have a rough idea only.
    LOL several people have told me that. Yes, you have to fill in the holes with bondo or fiberglass resin. The emblem in the top grill was sawed out and filled in as well. It took several hours to get it all smooth and stock looking.
    Ground is just allowing routing away excess unused power. You can just ground it directly to the frame. (+)Red is for power, (-)black is for ground
    94 rolla Guest
    basically, run the black wire to your chassis... if you see metal on your frame, just go ahead and find a bolt and run the black wire there. its simple
    JordanInc ZZE110
    i'd like to see pics of your setup and the finished product [=
