Engine install fuel, oil, tranny coolers?
Discussion in 'Powertrain' started by GSE21tuner, May 13, 2004.
    Can somebody run me through on how to install these coolers? I will be getting them soon and I want to do it myself. Do you know if these will add any power besides extending the life of the car? I know the fuel cooler might add.
    Vamp Gunmetal 2001 Corolla S
    Rosedale, MD
    Gunmetal Grey 2001 Corolla S
    Hmm, I thought I had put up a DIY on installing the tranny cooler. Guess I should get started on that. Installing it is pretty easy. There is no performance gain, just less stress on your engine/transmission.
    Fuel: not needed unless you install a return line
    Oil: not needed unless you're running a turbo
    Tranny: not needed unless you're running a high stall TC or F/I
    toyotaspeed90 New Member
    Bellingham, WA
    you put the same question on CC and i answered you already.....
