Engine injectors on ebay
Discussion in 'Powertrain' started by kudkud, Aug 14, 2006.
    kudkud Member
    Port Charlotte, FL
    some people say the supra injectors will work, some don't... its all speculation really so until someone actually does it, posts pictures and says its good to go, i couldn't tell ya. fuel rail should be fine, however the only concern is the clearance on the head.
    Barnacules 100101101011011
    Duvall, WA
    I have Votex's old Power Enterprise 550cc injectors, I ended up not using them in my Turbo Setup. If your interested PM me an offer. I paid $350 for them if I remember right, Vortex?
    jtweezy New Member
    Irving, TX
    Vortex c'mon yo.... you know I'm using these on my setup...well I had the limegreen injectors rated at 315 cc......fit and dont need another rail....I still have mine and will sell for 45 shipped...let me if you want them...
    kudkud Member
    Port Charlotte, FL
    The reason I asked is I bought the the turbo for sale on ebay to start my project. I will be buying parts little by little (every payday) and the next part I will be buying are the injectors. I don't know if I want to go for 550 injectors but from what I understand (which is not much) 440 injectors would be ok. Am I correct in ASSuming this?
    JT: weren't you setup for turbo before? How did it go? what injectors did U use?
    totally forgot those were supra injectors...
    kudkud Member
    Port Charlotte, FL
    Vortex,
    What injectors are you running right now?
    jtweezy New Member
    Irving, TX
    I used the 7mgte lime green top injectors and they worked great....I had money issues and had to sell everything.....other than that the only hard part was the tuning...I couldn't get the damn emanage to communicate!!!!
    kudkud Member
    Port Charlotte, FL
    Would you recommend eManage? Doc is selling an SMT6. Would that be better than eManage?
    I placed a bid on the injectors. If ever I get it, I will have 2 extra ones in case a couple fail.
    Next thing I'll try to get are the wastegate and BOV. Then IC, air filter, and piping. Last would be fuel management. I already bought Turbo, manifold, oil inlet, oil outlet, oil pan return, & exhaust connector.
    What am I missing?
    jtweezy New Member
    Irving, TX
    I hear that its easier to work with...but honestly dont have a clue....I would say just go with SAFC..but that would be cutting yourself short since it only controls A/F ratio.
    kudkud Member
    Port Charlotte, FL
    Thanks for the info.
    jtweezy New Member
    Irving, TX
    But if you can find a shop that can install the emanage and tune it...then that would be your best option.
    kudkud Member
    Port Charlotte, FL
    There's a shop that is less than 40 miles from where I'm at. They have a chassis dyno and all but they specialize in Mazdas & Corvettes. I don't know if it make a difference. Anyway here is their website:
    http://thedynoshop.net/
    eManage I would assume is quite common, right?
    MWR 380 cc injectors... they cost about 330 or so.
    kudkud Member
    Port Charlotte, FL
    Ok, thanks for the info. I saw that at MWR website but I do not want to spend too much, not yet anyway.
    trdracing2005 New Member
    Portsmouth, virginia
    kudkuds pic scares me
    jtweezy New Member
    Irving, TX
    i got me injectors for sale...40 shipped...with clips
    kudkud Member
    Port Charlotte, FL
    :lol That's my son. Extreme close-up w/ flash. He's actually a little tan.
    This is me on the right and my daughter on the left.
    JT: If I don't win this one, I might consider buying yours. I'll see what happens.
    UPDATE : 08/16/06
    I just won the auction for the supra injectors for 20.50 + $12.00 shipping for 6 pcs. Thanks for all your help and info
