Engine injector
Discussion in 'Powertrain' started by corolla_man_j, May 6, 2004.
    corolla_man_j Guest
    so sean to sean. you said that you are using the stock injectors and they work ok for you? I was thinking about going with rc310's but, I wasn't sure if I would really need them, what are you using for fuel management, I've got the e-manage with all of the harnesses
    corolla_man_j Guest
    injector
    ok....heres the deal. I have e-manage, and a t-25 turbo. I am only going to be boosting at most 10 psi , but more than likely 8 psi to stay safe on the side due to the internals [stock]. That isn't the question..the question is,I know of at least one person that is boosting on stock internals with stock injectors also...would stock injectors be ok for the psi that I'll be running , or will that be weak...BTW what cc are is the stock injectors for the 98
    turbo4age Love to Hate me
    NV
    ok, to the best of my knowledge ALL toyota injectors use the same harness and even the same injector seals.
    if i was to do a turbo buildup id get some oem supra 550s or some 3sgte injectors..... after that you need a pump to feed them and a way to control them (e manage)
    99rollaguy Guest
    yeah, I've heard the supra's 550s work
    sean2sean Member
    so cal
    i boost up to 11psi and they are fine.
    Stock's worked fine for me up to 9psi. Max duty cycle @ 9psi was 82% according to the eManage... *shrug* do remember our actual engine is *not* in the eManage so that could be a misrepresented number. However, like I said - I ran up to 9psi (sea level calc there btw) on stocks.
    corolla_man_j Guest
    ok....so vortex, you are using emanage, so did you use all of the optional harnesses that you can get for the e-manage? and you said that 1zz-fe isn't in the e-manage...then which one did you use? thanks
    Yep, I used all the harnesses... I'll post up a link when I get home tonight to the eManage manual I wrote for our cars. :)
    corolla_man_j Guest
    sweet...i'll need that bro
    corolla_man_j Guest
    ^bump-biddy-bump^
    blancokracker Guest
    i wouldn't mind that either than, im getting my e-manage installed this month
    corolla_man_j Guest
    i think that I am going to try to install it myself....I think that it should be rather straight forward
    yeah there isn't anything reall *that* mystical about the install... lol
    sorry this took till this morning, went home with a migraine last night and just crashed out on the couch... hehe
    http://www.dynamic-driving.com/~tsa...-up-corolla.pdf
    blancokracker Guest
    In My Opinion
    corolla_man_j Guest
    heh....that what I thought....thanks....now I am trying to remember a word....it starts with " O " ....i think
    corolla_man_j Guest
    just remembered it....oxymoron.....it really did uncloud my brain remembering the word....I had a whole bunch of " O " words floating around....weird
    corolla_man_j Guest
    sweet...I'll take it and run wiff it thanks alot :D
    toyotaspeed90 New Member
    Bellingham, WA
    you could also look for some 350cc 4a-gze injectors..... the latermodel gze's were around the boost you're looking at so it would be a good match IMO
    corolla_man_j Guest
    what does IMO mean....I've been wondering for about 3 years now
    cleanrolla97dx Guest
    Hey Crackhead Give Me A Call On Sat:d
    Hows The Turbo Scavenger Hunt Going?
    no problem :)
