Information on Body Kit
Discussion in 'Exterior' started by rainbow_star, Apr 18, 2005.
    Looks like the 01-02 TRD kit :p
    nysoundwaves Guest
    that's the stock dealer kit...it's an option for all CEs and LEs from 03+ i believe.
    well they're both made by toyota..maybe that's why? :p
    corollarider19 New Member
    just looks like the s kit to me
    Rare Rolla New Member
    its basically the same styling as the TRD kit for the 01-02 but it is factory applied in the S model in the 03+
    It's totally different than S kit.
    RollazIncJohn Guest
    That the Stock kit for the TRD Made Corolla just like the Altis Corolla is different as well, Plus the TRD Corolla comes with 17" Rims instead of 15" alloys or hubs that you get with all the other Corolla Packages, cause it's like you can buy a Toyota Tacoma or you can get the TRD Tacoma so it's just a different Package when you get it from the dealership
    tunerperformance New Member
    florida
    thats a diff kit that kit is the kit that is supposedly the special edition for the corolla you can get the trunk lip from ebay and the others you will have to find cause the back ground effects are diffrent than the s the backs have and added lip that goes up and down the fronts are the same though you should be able to go to a toyota body shop the and tell them what you want just the front and rear ground effects from the limited edition corolla s and they should be able to get them for you very expensive though
