Increase MPG?
Discussion in 'General Discussion' started by litoblee, Feb 1, 2010.
    litoblee New Member
    Increase MPG?
    I bought a '98 corolla recently and I was told they could hit some high MPGs.
    I tried calculating my rolla's MPG, if I did my math correctly, it only gets 16.7 MPG city.
    It's winter time right now where I live, so i have the heater on.
    But 17 is pretty low still. Kind of disappointed on that part.
    Is there anything I can do it to increase MPG?
    I've read the articles on ecomodder on hypermilling.
    A few things caught my eye, but i was wondering if anybody had anything specific for a corolla.
    nyrican52884 Active Member
    Plymouth, MA
    So when you calculated it, you took the miles driven from your last fill up and divided it by the number of gallons it took you to fill the tank, right? Well if your math is right, the best thing to do is perform regularly scheduled maintenance. Pretty much everything else is a gimmick or not practical (spend too much and you won't save much). How many miles do you have. Try changing your air filter, spark plugs, wires, pcv valve, etc. Do you have CEL? or anything else that might lead to an answer?
    JrollaS Member
    Lancaster, Pa
    this is kind of obvious but also the way you drive. if you have a manual, you can increase your mpg pretty easy by just driving smarter and less aggressively. but definitely what nyrican said, regular maintenance is key. Dont forget to check your tire pressure.
    I have a few tricks for getting good mpg...
    keep tires at vehicle rated pressure or higher (within 5 lbs of rating on tires)
    keep engine in good shape (air filter clean)
    leave passengers on the side of the road (they're too fat)
    drive with stock alloy wheels or something even lighter
    shift at 3k rpm whenever possible
    JrollaS Member
    Lancaster, Pa
    haha the best advice is leaving the fat people on the side of the road. thats great!
    lmao
    i tucked my seat belts and all that other shit underneath the cushion and tell people i have no seat belts LOL
    Plymouth, MA
    Oh, I forgot that one. Losing weight will up your mpgs big time
    svrolla Member
    how i drive my truck...:shutup:hummers get better mpg
    Edwin562 SWAG MASTER
    562 SoCal
    98 180sx
    haha i do the same thing!!!!!!!!!
    :Own3d:
    keolaaina Well-Known Member
    I bought this to help me keep an eye on my MPG's
    I have an automatic with badly worn front tires and some messed up alightment(gonna get both fixed as soon as I get an extra $300) and I get around 30mpgs give or take mixed.
    Along with the above mentions, make sure your tires are in good shape, and your alighment it within spec.
    I make up all of the high mpg's on the highway, i found that going 75-80 mph at about 2.5 grand,where I drive that's in a 55-60mph zone where most people drive between 60-85. The trick is to find the lowest rpm at which the mph needle still very slowly climbs. That's when you get your peak mpg's in terms of just using the throttle.
    How much is that and where can I get it?
    SaberJ2X Lurk MOAR
    Mayawest, PR
    I also got about the same in my rolla in the beginning...
    now I'm rolling 24mpgs... but...
    featherwieght konig, proxes 4 tires @ 42psi
    deleted catalyst
    weaponR secret intake
    seafoamed the engine
    NGK oem spark plugs - no fancy shit here
    a good wheel alignment never hurts
    took all the shit I could out of the car- (still got audio system and a jack in the back)
    high pressure radiator cap
    re-grounded the whole engine with additional points and fatter wires
    the de-gunked the transmission with the appropriate seafoam product
    new seals for the valve guides...
    and I think that's pretty much it...
    except the feather weights and the regrounding I think it all falls down in maintainance
    most important of all... don't gun the poor 1zz at those green lights, and don't over rev it (much :D)
    I seafoamed my car 3 times cause the last owner was an old bag, but I don't recommend you do them back to back, wait atleast 2 months in between... (O2 must burn all that shit that the engine spews when you do them)
    litoblee New Member
    thanks for the advice!
    nyrican, i don't know what a CEL is, i'm pretty new to the auto world.
    i'll definitely look up on how to keep maintenance on those things.
    I drive how it recommends you do on ecomodder, just coast and all that.
    Probably because most of the time i've been driving, i've been carpooling with 3 additional people in my car.
    keo, where do you get one of those MPG moderators?
    saber, how is that weaponR intake? i was looking into getting one.
    CEL = Check Engine Light
    I bought mines from ebay. It was about $80 and I think it was worth it. All sorts of features. There are other ones that are more expensive and have more features.
    the scangauge II does that too right? I heard that will give you at the moment horsepower also.
    SaberJ2X Lurk MOAR
    Mayawest, PR
    a scanguage?
    Plymouth, MA
    I don't think it will give you horsepower, but it will give you info like engine and transmission temp, oil pressure, etc.
    The most important factor for gas mileage is also the most obvious. Maintenance! Stay on top of your tune ups, spark plugs, oil changes, transmission oil changes, and keep your tires inflated to the correct psi. Other factors will include weight as mentioned above. Lighter wheels will help some. They will help in reducing fuel use in accelerating slightly, but due to the lighter weight, they will require more fuel to maintain speed since they won't have as much momentum to drive them. For city traffic, lighter wheels are your friend. For highway not so much, but you do have better steering response and handling. ;)
    I've found that the type of tires you have also makes a noticeable effect. If you have hard commuter tires that are usually rated UTQG 500+ you will get 3-7 mpg more than high performance performance UTQG 200 tires. to hit the 40mpg highway rating of the rolla you almost MUST have steelies or something lighter and mid to low grip tires
    JrollaS Member
    Lancaster, Pa
    i read an article in car and driver i think... maybe car craft... i dont know but it said there are new michelin tires that are supposed to reduce drag and boost fuel economy. i think there were 4 brands that are making such tires. dont remember which ones though. its worth checkin out. i read the article in the bathroom at work so ill try and find it again tomorrow.
    Plymouth, MA
    The Michelin tires that give you good fuel economy are in the commercial with the giant evil gas pump that sucks the money out of the people.
    I was saying that it gives you a reading of your current horsepower at the moment, like what your car is making. Didn't mean to imply that I think it GIVES your car more horsepower. lulz.
    And those tires are called the Michelin Energy Saver. Very creative in choosing a name, as you can see. :D
    I completely forgot about different speed tires. You're definitely not going to want sticky V or higher speed ratings. H's are a good compromise of grip and mileage. Or if you want hardcore mileage, go with T's.
    SaberJ2X Lurk MOAR
    Mayawest, PR
    hence why I filled my tires up to 42psi
    Plymouth, MA
    That's what I meant. I don't think it gives a HP reading. I think it does give you a 0-60.
    Hmm... I thought it did a lot more, I'll look into it.
