Engine I'm ordering my clutch and flywheel today
Discussion in 'Powertrain' started by Barnacules, Dec 3, 2004.
    Barnacules 100101101011011
    Duvall, WA
    Okay so I'm cruizing www.ultrarev.com adding stuff to my cart but they dont show ACT clutches for 2001 corolla only 2000. Dont all the corolla from like 92 - 2002 take the same clutch and flywheel? Could someone please confirm this for me before I order. I had to adjust my search to 2000 corolla to find the ACT XT-XTSS which is the clutch I think I want. I need to get this stuff ordered today though cause my car doesn't go up hills anymore the clutch is so bad so any help or insight would be great.
    Thanks in advance...
    CadetLee Guest
    93-97s have different engines; 98+ Corollas and 2000+ Celica GTs use the same clutch (1ZZFE engine).
    Duvall, WA
    Sweet, Thanks for the input. I'll submit my order now.
    Duvall, WA
    It's a done deal :)
    ACT 2600 Clutch Kit Toyota Corolla 6/92-00 1600/1800cc 212mm (Torque Capacity:( 275 (Pressure Increase:( 65% (ACT Pressure Plate:( T-022X (ACT Disc:( TYSD035S (Release Bearing:( RB840 (Pilot Bearing:( N/A (Alignment Tool:( ATK73
    Note: Image shown may not be for your specific vehicle.
    Item #TC2-XTSS 1 $387.50 $387.50
    Fidanza Aluminum flywheels Toyota Corolla 98-03 1.8L FWD Weight: 8.5 Code: TO14
    Item #130231 1 $359.00 $359.00
    Power Slot Slotted Rotor TOYOTA 1993-2002 COROLLA FRONT LEFT ROTOR
    Item #741PSL 1 $76.13 $76.13
    Power Slot Slotted Rotor TOYOTA 1993-2002 COROLLA FRONT RIGHT ROTOR
    Item #741PSR 1 $76.13 $76.13
    Hawk Performance HPS Brake Pads TOYOTA COROLLA 2002-98 Front
    Item #HB321F.650 1 $61.10 $61.10
    Product Cost $959.86
    Shipping Cost $72.11
    Coupon Discount ($28.80)
    Total $1,003.17
    Duvall, WA
    The car is almost back togather today sitting out in the garage. We finished bolting up the new Fidanza flywheel and Act XT clutch. Should be fun to drive when I'm all done. I'll post pictures when its complete.
    Lekz Guest
    DAAAMN your clutch setup is expensive...are u turboing the car?
