I'm a little concerned about this.....
Discussion in 'Stop, Drop & Roll' started by Cuztomrollaz98, Mar 23, 2005.
    Cuztomrollaz98 MAD VLAD!
    Littleton, CO.
    Well I just noticed that my car sits really really low on the rear as well as the front to be stock suspension and there's no extra weight in the back whatsoever so I was wondering if it's that the suspension is like really worn or what's up with that since I don't feel like becoming another I-25 4:00 pm radio station accident statistic due to that lol so anyone run into this kind of thing before?
    teevee247 Well-Known Member
    Montreal, QC
    my rear suspension was sagging alot... my struts we're done... and i mean done... no damping whatsoever... might want to get them checked out
    Phozenstone New Member
    depends on wut u consider saggin really, do u have any pics? usually the rear is lower than the front, even when the car is stock, but i mean if ur tires are tucked maybe u need new struts.
    Prodigy3006 Rubber Man
    Alabama
    keep it gangsta or get new struts ?
    Littleton, CO.
    I'll probably replace the whole suspension with some performance.... what do u guys prefer to buy for struts, springs, shocks and all that??? Let me know with some options of some good packages thanks.
    e_andree E
    MD
    How olds your suspension?
    Littleton, CO.
    never changed it or altered it in any way
    e_andree E
    MD
    So its 7 years old.....ya know that struts and springs fade with time? Wear and tear item that doesnt last forever.
    Littleton, CO.
    yea I know... well I guess I'll just replace it fook it lol with what kind of suspension kit would u go e_andree?
    e_andree E
    MD
    I personally liked the kybs and eibachs....but ya have lots of options.
    Ive heard good things about Intrax and H+R as well.
    Just try to push down the front and the rear as hard as you can. Then see how many times it bounds back. If more than once, then the struts are dead.
    Littleton, CO.
    shit the car bounces like 20 times lol plus when like 1 person gets in the back the whole car lowers like to the ground lol well I guess it's time for new toys on my rolla lol....time for some bank hehehe
    xnevergiveinx New Member
    north royalton, oh
    your springs and struts are shot. replace them, do it yourself, it's not too hard. vamp has an awesome tutorial on it, really helped me out with mine.
    my rear end was sagging bad and it would boucy a bunch after a bump. i replaced it with dropzone coilovers, i wish i would have read reviews before investing in them. i did the front, i had my friend do the back, he has an impact wrench. dropzone coilovers are awesome for looks, i can tuck my wheels pretty good, but they suck for comfort! my car takes turns like it's on rails though...so i'm happy, but i'm selling it soon.
    funny thing, i took off the right side front strut and i pressed it down, it didnt come back up like it was suppossed to! instead, it just stayed there, so i pressed it down all the way...it started spewing out fluid that stunk like hydraulic fluid...the drivers side strut would push down and come up, but it took more than 12 seconds to totally come up, i could push the strut piston down with my pinky finger. my new struts came up so much quicker and were harder to push down. yeah, those stock struts were funny.
    Littleton, CO.
    Yea I'm probably gonna spend in the whole suspension like sway bars, new shocks, struts, springs etc... I might even do the rear brake conversion and the 5 lug nut conversion while I'm at it too
    sorry to bump an old thread, but I'm getting a bit concerned about my rear wheels on my 02. I can't tell if my springs are sagging or if the camber is just that screwed up. my front wheels have a slight negative camber, but my rear wheels seem to have visibly more negative camber. I drive the car pretty aggressive through the corners so should I bother? it might be helping me at this point. before the negative camber issue the back end of my car would slide out very frequently, now it has mostly stopped.
    JDMjody VVTLi > VTEC
    RIVERSIDE, CA
    04 Celica GTS
    ha, i dont think anyone EVER replaces the rear suspension :D
    Ares Active Member
    Houston TX
    CB:
    good camber = even wear and tear on rubber. I honestly cant tell you why negative camber is helping you regarding the sliding issue. How are your tires/tread?
    Littleton, CO.
    Damn talk about REVIVAL! lol, I posted this thread when I had my 98' lol
    rolla02 Corollalcholic
    Delaware
    nyrican52884 Active Member
    Plymouth, MA
    CB, you should know better than to revive a 4 year old thread LOL. But the rear does habe more camber than the front. The rear is supposed to be 1.0 degrees and the front is supposed to be 0.4 degrees. I would only worry if you see extreme sagging or one side has more camber than the other.
    Ares, more negative camber will allow you to handle better because as you take a corner the whole car tilts, and if you have negative camber the entire tread of the tire will contact the road. Hence why he's getting better grip. But it could be due to something else that was changed, because I think sagging springs would outweigh slightly negative camber.
    Ares Active Member
    Houston TX
    ooooooooooooic. *pictures in his mind*
    yeah I rarely have anybody in my car or anything heavy in the back so the springs should sag less than most. I just replaced my tires.
    oh and I revived because I didn't want to make a new one.. info still applicable.. so there! :p
    Ares Active Member
    Houston TX
    wrd @ info applicable. But it might be easier to just creat a thread rather than look for one like this no?
    its_ikon FIRST widebody
    Henderson, NV
    whats funny is people will say something about bringing back an old thread, but then when someone makes a post that's been discussed before the common response is "search"
    yeah I go by the posting and you rules.. bump always better than new thread
    Ares Active Member
    Houston TX
    oic.
    Littleton, CO.
    That is very true, at 9thgen is the same thing dude
    RIVERSIDE, CA
    04 Celica GTS
    search!! lol
    :D
    Littleton, CO.
    well obviously he did search but just to revive the thread and ask lol
