If I change to altezza, do i have to.......
Discussion in 'Exterior' started by NsK, Jun 7, 2003.
    NsK Guest
    i have a lunar rolla 03, if I change the tail light to the 1st generation of altezza in chrome..........do i have to change the bulbs inside for others to be able to see me when i'm backing up my car..................if so, what's the size...of the bulbs.
    nakanari Guest
    Re: If I change to altezza, do i have to.......
    hey bud. u don't need any wring job. also u do need origanl light bulb set to put inside the cover.
    stinky Guest
    like nakanari said. All you got to do is transfer the bulbs from your stock housings into the new ones and you will be set to go.
    NsK Guest
    ok because i though we need to change the bulbs inside to be able to see the light when i'll back up the car...........if you know what i'm saying.............
    nakanari Guest
    i don't think so u need changed any light bulbs. becasue OEM is light bulbs is alredy has
    singnal , breaks, so after u install it just asked some stand behind the car and make sure all your light is work when u test break or singale.
    hope this help.
    tony
