I need sticky tires for track/street
Discussion in 'Stop, Drop & Roll' started by JLee, Nov 1, 2009.
    JLee TD05 3SGTE
    NH
    I'm gunning for 12's next spring and my Kumho AST's aren't gonna cut it. Unfortunately, I don't have much to choose from.
    I can get these in 225/50/15:
    Kumho Ecsta AST (have now)
    Nitto NT 450
    BF Goodrich G-Sport
    Yokohama AVS ES100
    Sumitomo HTR 200
    Toyo Proxes T1R
    Pirelli PZero System (very expensive..would rather not spend $200/tire)
    What do you think?
    I know I'd be better off with drag radials, but until I get a couple of extra wheels, it's not happening.
    Rincon , Puerto Rico
    I like the Toyo Proxes T1R and the Nexxen N5000 series :)
    rolla02 Corollalcholic
    Delaware
    Yoko S-Drives or Dunlop Direzza Star Specs.
    I got the S-Drives on my car now (235/45/27) and they stick like glue once they warm up which doesn't take long.
    I got a buddy running the same size but the Dunlop's and they stick like glue too.
    JLee TD05 3SGTE
    NH
    I can get the Nexen N2000, but no dice on S-Drives, Direzzas or N5000's. This is a tough size to find.
    The only reason I would say no to the N2000 is cause they have the same pattern as the N3000 and in my opinion they blow , They not comfortable and when they get low they slip in the rain , Thats why when I purchased the N5000 it was totally different feeling ... Another good tires is the Spectors and Capitol UHP ,,, Plus Hankook are awesome if you own a truck ....I know tires are tough choices and you have people living in different areas so where winter is different so a certian tire sells ... Just go with what your area calls for .... Even though I live in FLorida I use All Season tires cause there softer compound and they have more 32 seconds ... and ride smooth .... :)
    Delaware
    What size are you looking for?
    Goodyear Eagle F1's are also sticky
    rayray1 Active Member
    Out of those, I'd get the Sumitomo HTR 200, or the ES100s.
    But they are older models though that have been replaced with newer, better ones.
    Why not order some online and have them shipped to you instead?
    JLee TD05 3SGTE
    NH
    All seasons are not going to work. I'm pretty sure I will fry them.
    I don't care much about rain traction, either - looking for sticky first. I have BF Goodrich All Terrain TA KO x4 for bad weather. ;)
    That was online (TireRack, DiscountTireDirect and eBay). I tried a local tire place and they couldn't get anything in that size.
    out of that list, i like toyo's
    I consider all the tires on the list crap.. well T1R is decent.
    Actually I just read the OP again, since you're strictly drag, go with BFG.
    JLee TD05 3SGTE
    NH
    Can you find something better in 225/50/15?
    I was thinking u wanted track tires as in road track/circuit. But BFG would do just fine on the drag strip seeing as you don't need anything with large shouder cornering blocks or stiff sidewalls.
    JLee TD05 3SGTE
    NH
    :p
    Ty - I'm between the T1R's and BFG's..I'll have to do some research.
    Delaware
    JLee TD05 3SGTE
    NH
    ooo those look good. Pricey, but I think it might be worth it.
    I have a set of RE11's, they're alright... definately better than everything else listed.
    I used to have some MIcky Thompsons they were awesome on the road and rain but when you go over a metal bridge it was scary :)
    Delaware
    Trust me man I know what you mean.
    Its gonna cost me at least 500 bucks next year for my tires, and they will prob last 6 months....but then I am also running a 235/45/17 with a mild camber adjustment.
    las vegas
    personally i got the BF Goodrich G-Sport on my evo8 and i really like it.the tire really grip on turns,i bought mines tire discount for $600 235/45ZR17 w/out warranty.
    Edwin562 SWAG MASTER
    562 SoCal
    98 180sx
    go with azenis
    Wish I lived in an area with nicer weather so I could run those tires. Too many sudden downpours here.
    I'll probably settle for S.Drives or Kumho SPTs next spring.
