Engine I need a muffler
Discussion in 'Powertrain' started by System Error, Nov 24, 2004.
    System Error Guest
    I need a muffler
    I need a single inlet/ dual outlet muffler the inlet and outlets need to be 2.5" and I need to be for sportcompacts (small displacements) not V8's
    where can I find one....magnaflow has a bunch..but I don't know if they're for small or big displacements
    HK-Racer Guest
    you can always check ebay.
    superpilun Guest
    why dual outlets? i know dynomax has them. they sell various sizes, and can place the inlet in the center or offset. check them out. if you're just going with a custom setup, consider getting the longest thrush cherry bomb resonators you can find that can fit under the car. they are cheap and effective.
    d_samurai Guest
    you'll kill your low end power...
    System Error Guest
    I'm not running dual exhaust.....I just want to run dual tips. It just like a regular dual tip muffler....just with realy long tips. I'm either going 2 ways.......I know I'm going 2.5" piping from the turbo back. But I'm either going to go with a 2.5" cat, no resonator, single dual outlet muffler and then just run the tips to both sides of the car...or I'm going to run it like the SRT-4's with no muffler. I'd have to check to see what else the have installed to quiet it down though..I'll probably go the first route though......I shouldn't lose any power....I need the 2.5" piping...my stock piping is to constrictive for my turbo.....and I'm not running 2 mufflers in some fake wannabe dual exhaust system. Just dual tips....it will still be a single exhaust system.
