Engine I found an engine i like
Discussion in 'Powertrain' started by 97rolla-s13240sx, May 29, 2005.
    97rolla-s13240sx Guest
    sxlostv1 New Member
    Los Angeles
    too bad you live in georgia. you can get those easily in socal if you got the money
    JDLangevin Guest
    That's a blacktop 20v, turbocharged. It's also set up for RWD from the looks of it. I can swap one into your car and turbocharge it if you like.
    http://www.phoenixtuning.com/
    JDLangevin Guest
    What are your power goals? Because if you just want around 170/180 hp, then go with the turbo kit. If you're going to want more, then go with the swap. You'll get more power now AND more potential for the future.
    -Doc
    how much money are we looken at for a set up like this one and also do you have any wheels you want to sell i really need some nice wheels and tires.
    JDLangevin Guest
    If you want it turbocharged like that one, with a full low compression rebuild, then you're looking at a good deal of cash. The engine alone is around $1500-$2000 including the tranny, wiring, and ECU. Add another $2000 for for the rebuild, plus around $2000 for the turbo parts, and then labor, which is going to run you another $1800. Then I always tell people to add another $500-$1000 because of little extras that always pop up. That's around $9000!
    There is a better way though. Get a 4AGE 20v Silvertop instead, and you'll save around $1000. Better yet, get one with a cut harness and ECU, and you should be able to get it for around $600 shipped. Now add another $500 for a standalone (megasquirt with EDIS), we're up to $1100. The rebuild will cost another $2500 with labor, and then the turbo parts and labor will be around $2500, so total including extras will be down to $7000.
    Drop the low compression rebuild and just stay with a low boost turbo (which you can do with the silvertop but NOT with the blacktop) and you can cut off another $2500, so you only have $3600 and then those pesky extras which we may be able to keep under $4000 total.
    Lastly, you can do JUST and engine swap for now, with the standalone, for less than $2000. Then you can do the turbo stuff down the road.
    -Doc
    WOW- you just gave me a head ach not to mention you are going to keep my up all night with all the informantion you just told me. I still think i am going to wait till you get that stage II turbo kit up and running. I would rather buy a kit then trust my knowledge of a complete turbo set up
    so is that what you are look at with your stage II turbo kit? I really would like it some where in the 225-250 range but not with any seriouse money but that will never happen. If i got your turbo kit that other mods could i do to make my car reach 225 or 250- also if you have a cat back or rims for sale i would love to buy them. i have been looken for those items forever and ebay never has a cat back for a 97 and they really never have any good rims that suit me.
