Engine I bought this muffler...check it out...
Discussion in 'Powertrain' started by CorollaULEV, Jul 7, 2004.
    CorollaULEV Guest
    I got a Magnaflow SS 5" x 8" muffler. It's part no. 14235 on this page.
    http://www.magnaflow.com/02product/ss.htm
    It's offset/offset with 2.25" diameter. Think this will do the trick?
    I'm having the exhaust shop custom-make a 2.25" resonator-back exhaust when they put the muffler on. I'm leaving the resonator at the advice of the shop guys - they said it'll sound a lot better with the resonator left in. Should I have them weld in a different resonator or do you think the stock one is ok??
    Thanks,
    Trav
    TheBeak Guest
    how much cheaper than the full catback was this muff plus all the custom work?
    going to be mandral bent or crush bent?
    IIRC the outlet of the stock resonator is where it becomes restricted, hence it getting cut off with the full catback.
    imported_j_yota Guest
    My bro has the same muffler. If you remove your cat and res, it will be really loud.
    CorollaULEV Guest
    Definitely not gonna remove the cat - I pride myself in having a ULEV certified vehicle....I'm gonna keep it that way. The resonator will probably stay as well, because I don't want anything obnoxious.
    The cat-back system from Magnaflow can NOT be had for under ~$375. That includes muffler, piping and a resonator. It includes EVERYTHING from the 2nd cat back. Other cat-backs are similarly priced (Borla, TRD, etc.) and is ONLY the rear section (axle-back).
    The SAME muffler included in the Magnaflow cat-back - I purchased it for $76 (shipping was free). The piping and install from the shop shouldn't cost more than $75 and probably not that much. Mandrel or crush - dunno yet b/c I didn't ask.
    Pipe b/w 1st cat and 2nd cat is huge (3"), pipe b/w 2nd cat and resonator is big enough (2.5"). You're right - from the resonator to the muffler bottlenecks to a tad smaller than 2" (like 1 15/16") and that seems to be the restrictive part of our exhaust sys.
    My deal is this: I don't know what's inside the resonator (is it a straight-thru design) and I don't know if the res itself is restrictive or not. Anyone venture a guess?? Should I get a DIFFERENT res welded in or leave the stock one??
    Late,
    Trav
    imported_rollaracer4 Guest
    I just got a custom exhaust. i got full pipes all the way back to my muffler and the cat and res removed ,and it sounds mean ! and i got it from just under $200.
