Engine Hyper Voltage System
Discussion in 'Powertrain' started by skyy, Aug 19, 2004.
    skyy Guest
    does anyone have a HVS installed in your rolla?
    if yes, what brand? what type? how much?
    does it make any different?
    share some experinces
    polo708 New Member
    9thgencorolla.com
    they run about $130ish... sunperformance or sun-something, you can find them on Ebay too. Dont work well IMO, but have heard differently. Its up to you...
    DocHolliday Guest
    Don't spend $100+ on a grounding system when you can make your own or buy a set on eBay for under $30. The whole point of the system is to increase the efficacy of the electircal circuits by provinding more and better grounding points.
    Import Tuner has shown (via a dyno) gains on various vehicles with ground wires, but nothing to write home about. IMHO, for something that will run you $30 or less, it's worth the 10 minutes it will take to install. Even if it doesn't "free up" any ponies, it will help with your electical system.
    polo708 New Member
    9thgencorolla.com
    he's talking about the voltage system, not the grounding kit.
    skyy Guest
    right now, i am doing the grounding system,
    i bought 4 gauge cable from ebay, 20 ft around $12
    and some ring terminals for $10
    after this project is done, the next thing is HVS,
    but it's expensive, so i am still thinking of it is worth to buy
