Hub centric spacer/ring?
Discussion in 'Stop, Drop & Roll' started by cgreen38, Mar 11, 2007.
    cgreen38 Common sense, p
    Baton Rouge, LA
    I never thought about this that much until today, but should I have hub centric rings or spacers (i'd do 5mm, maybe 10mm) on my 98? If so, can someone point me to a good brand for them? Also, would I need them on just the front, or on the rear, too?
    BTW, I have 16x7 Rota wheels on my car w/ 205/45/zr16 tires (if that makes any difference at all). :eek:
    I find that my acorn style lugnuts center the wheels perfectly onto the hub so I never needed hubrings (I have no vibration problems what-so-ever). You don't need spacers unless your wheel offset is incorrect or you want your wheels to be pushed out more..
    Baton Rouge, LA
    Cool. I was just wondering. I've had a slight problem, but I've heard that dead struts can do that. I'm about to go get a new set of lugnuts, too. I have some cheap ones from Autozone, and I'm about to get some new ones that are actually worth something. :)
    Tulsa, Ok
    thats what i have....cuz honda made them stock on my model civic, hehe...
    muteki is good for budgit minded folks.
    I run rays duralugs myself.
