Hows my belt look?
Discussion in '8th Gen' started by Hummer, Dec 12, 2008.
    Hows my belt look?
    I dont think its good eh?
    hard to tell from the image but you should eventually replace it.
    Doh! Yup, definitely need to replace that. It probably would still hold, but why even bother and risk it for a $30 belt.
    What caused that groove to be cut into the belt - something got stuck on the pulley? Make sure you clean the pulleys before you slap a new belt back on there.
    just replace it, its cheap and easy..
    dward3 Well-Known Member
    Phoenix
    more night pics :rolleyes:
    i work all day!
    Ares Active Member
    Houston TX
    What everyone already said... Cheap replacement before it breaks and takes something else with it...
    Legit01Rolla Active Member
    doesnt look good at all..change it b4 its too late
    after a closer inspection, you should also check the tensioner under the alternator.. look like that thing is scoring the belt! it's supposed to be perfectly smooth.
    I take it you never replaced it?
