How to pick the right tires for the season
Discussion in 'Stop, Drop & Roll' started by RinconRolla98, Jan 12, 2010.
    Rincon , Puerto Rico
    Winter tires only have to save you from tragedy once to be a worthwhile investment
    Did you know that below 7˚C, the rubber molecules in your summer-spec tire treads progressively harden and freeze? This means the tire is less able to adapt to the contour of the road surface, which in turn reduces grip levels, to such an extent that when braking on a wet – not icy – road from 50mph, summer tires will need 40 meters to stop, when winter tires will stop in 34 meters.
    It’s a big difference and it’s surprising how few people know that there is such a fall-off in performance of the tires we normally buy, just because the weather is colder. Of course, the difference on ice and snow is even greater, as the winter tires’ design cuts through snow and into ice to give a far greater margin of safety than on normal tires: braking on icy roads from 20mph, summer tires take 68 meters to stop, while winter tires will bring you to a halt in 57 meters.
    In northern or mountainous regions of Europe where locals are often required to fit winter tires, the fact that yours is on summer tires will make insurance companies blame you first for any accident you’re caught up in. Germany requires drivers to swap tires with the seasons unless using ‘all-season’ tires.
    Of course, it’s wrong to look at these comparisons in isolation: there are many more influences on tire performance. Pressure is one. Manufacturers used to recommend that winter tires were inflated to slightly higher pressures than their summer equivalents, on the grounds that winter tires don’t heat up as much in the cold weather, but Robin Winter (yes, really...) of Vredestein says that the advice now is to maintain normal pressures.
    Tread depth also affects performance. The difference between a new tire and one worn but just legal is even greater than the wet road comparison above.
    The age of the tires can have an even greater effect, partly because modern compounds are around 30% better in braking than they were 25 years ago, but also because age hardens tire compounds and makes them less supple and hence less grippy. There’s increasing evidence that we really should change our tires once they’re 10 years old, whatever their wear levels. How do you know the age of your tires? Use the checklist below…
    So why not use winter tires all year round? The simple answer is that at higher temperatures, on wet or dry roads, they’re not as good as summer tires: tire technology has moved forward a long way but temperature still has a big impact on longevity and performance.
    As a result, we have summer tires, winter tires and all-season tires, the last a compromise for all-year-round use but not matching the ultimate performance of either winter- or summer-specific tires.
    Winter tires use a higher proportion of natural rubber, with silica compounds to maintain flexibility in cold conditions. Michelin’s Alpin range (made in Dundee, Scotland) even use a compound containing sunflower oil for better wet grip. Winter tires also have far more sipes for cutting through water and deeper tread than summer tires but the side effect is that they can make the steering feel imprecise in the dry; much effort has gone into encouraging the sipes to ‘lock’ when cornering, to reduce this effect.
    With current tire fitting costs, the most cost-effective way to use winter tires is to have two sets of wheels (usually steel for winter, since alloy corrodes so badly from road salt) and swap summer for winter in October, then back in April. About 25% of motorists on the European continent do exactly that. If you use your car all year round, the arguments for changing to winter tires when the temperature drops below 7˚C are compelling.
    How old are my tires?
    The DOT code, which is required for the American market, can tell you when the tire was made.
    If it ends with three numbers, it was made in the 1980s; if it ends with three numbers followed by a triangle, 1990s; if it’s a four-number code, 2000s.
    Within the code, the first two numbers are the week of the year, followed by the year of manufacture (single-digit 1980s/’90s, two since). So, 256 is the 25th week of 1986; 256 is the 25th week of 1996, 2506 is the 25th week of 2006.
    If there’s no DOT code, either the tires were not offered on the US market or they are over 25 years old… The two letters in the DOT code tell you the factory/country in which the tires were made: see www.carbibles.com/tiremanufacturercodes.html.
    What else can my tires tell me?
    M+S tires are for Mud and Snow; if they also have a very chunky tread pattern, they’re primarily for off-road use, but M+S-marked tires that are primarily on-road patterns are increasingly common. Winter tires that are marked with a snowflake symbol have passed an industry standard braking test on snow.
    All tires sold in Europe after July 1997, unless they’re for pre-1939 cars, must be E-marked (though there is no law to prevent you fitting non E-marked tires to your car). The code tells you the type approval certificate, the country in which it was issued (‘11’ in a circle is UK) and the European requirement it complies with.
    A yellow (usually) dot on the sidewall indicates the (fractionally) lightest spot on the tire – it’s impossible to get them absolutely 100% uniform. This should be mounted adjacent to the valve to minimize the need for balance weights. A red dot indicates the highest spot (it’s also impossible to get them absolutely 100% round). If the wheel rim has a dimple in it, that marks its lowest spot, so the two should be mounted adjacent to one another (this takes preference over the yellow dot).
    Radial colored stripes in the tread indicate a tendency for the tire to pull slightly to one side. If the stripe is near the centre, it will have little pull. If it’s further out, try to mount that tire opposite one that has its band to the other side, so they tend to pull/push each other. Remember, though, that some tires are unidirectional, so cannot just be flipped round.
    You may also find USA-required markings that rate the tire for temperature (its ability to resist heat build-up), traction (grip) and tread wear. Temperature and traction are rated as A, B or C, in descending order: ideally you want to see A or B on your tire. Tread wear is measured as a figure between 60 and 600, where 60 means the tire will be worn out in a few thousand miles and 600 means it will last into the next millennium. Much still depends on how you drive...
    Ares Active Member
    Houston TX
    Long read. Any cliff notes?
    All I know is this: I live in Houston and I should not worry about freezing temps but maybe 5 days in a year. :thumb:
    brownsville, tx
    sorry i just found the story ..LMAO :)
    Like ALWAYS lol
    lmao lmao :)
    i prefer these
    rolla02 Corollalcholic
    Delaware
    what website did u copy and paste this from?
    JDMjody VVTLi > VTEC
    RIVERSIDE, CA
    04 Celica GTS
    ROFL @ this thread
    :D
    Yea I just found this and posted it up , Just doing my contribution and posting some information for others to read :)
    mochatron New Member
    San Diego, Cali.
