how long will trd springs and tokico struts last????
Discussion in 'Stop, Drop & Roll' started by ecm0525, Jul 17, 2004.
    ecm0525 Guest
    Im going to get tokico struts and trd springs and I want to know if that worth to buy and how long are tokico stuts suppost to last....
    mncrolln Guest
    That is such an open ended question that it is hard to answer. Toyota says you should replace your struts every 80K. You should be able to get at least 60 out of the Tokico's but that really depends on your driving, the weight you will be carrying, the conditions of the roads you are traveling on etc...Mine rear struts only lasted 6 months but that is with Ground Control coil overs, 200lbs of stereo equipment in the trunk and bump roads. I think Tokico has some info on their website regarding wear. The springs might be good for the life of the car but I would suggest replace those every 60-80K (same time as the struts) as well. If you want to keep your suspension at the top of its game, then changing them out every 30-45K is pretty good (and expensive).
