How do you remove this stock speaker?
Discussion in 'Interior' started by rolla03, Jul 18, 2003.
    rolla03 Guest
    Can this stock speaker be removed to istall and aftermarket on the 2003 sorry. If so, how do you do it i can't seem to be able to remove it thx
    rolla03 Guest
    NM, i just saw the DIY. :D
    :D Ok, here's another.
    How do you secure the aftermarket to the bracket?
    ConwayJim Guest
    To be honest, i don't know how well, the new aftermarket speaker will hold up when it is screwed into the plastic mount. Oxymoron gave me a template of the mounting bracket, so i'm just going to cut it out of some MDF board and mount my speakers in there. that way if i want to sell the car in the future, i can still put back in the stock speakers.
    I can Email you a copy of the scan if your interested, or talk with oxy 8)
    03ToyMan New Member
    I imagine if you drilled holes in the plastic bracket (assuming you are going to re-use it) you could use tie-wraps (cable-ties) to hold them in. Think I'd put some kind of foam padding between the speakers and the plastic just to make sure they never rattled.
    oxymoron Guest
    Here's a picture of an adapter made out of MDF.
    03ToyMan New Member
    Wow that looks neatly done!
    darrenwang Guest
    yes that looks neat.
    I also made a spacer out of MDF but they are ugly...
    Oxymoron did a way better than me. It seems like plastic. Good Job!
    I notice that you cut the top cornor. How did you achieve that without breaking the wood while sewing it?
    xtm "Member"
    Panorama City, CA
    Mine holds up pretty well...PLENTY of midbass beating too. I never needed an MDF ring, it just went right in..snug into place.
    darrenwang Guest
    BTW I also put baffle between the spacer and the speaker to proection from water. You could get them from Crutchfield.com for $7 a pair.
    oxymoron Guest
    Cut very carefully with a handsaw.
    oxymoron Guest
    Yeah, you do have to protect the back of the speaker from water. I've got a plastic shield running accross the top and a 4 mil sheet of plastic draped behind. It's also a good idea to pack the spider with acoustic fibreglass to cut down on mid-range reflections off the door skins.
    SoCal_CJ Guest
    moderator please delete post, happy now?
    c0d3r Guest
    ConwayJim can you e-mail frozen208@yahoo.com me the template please? And about how much does the MDF cost for what I would need to make both brackets.
    -Scott
