How do you guys secure your subs?
Discussion in 'Interior' started by ChicagoCruise, Nov 6, 2009.
    I have a sub in my trunk that is always getting loose and moving just enough to make noise. I haven't found a way to fully secure it with no more movement.
    Any creative ideas you guys use?
    Ive been using L clamps, that i have to bend in order to stick to the trunks wall.
    I have an eye-ring screwed in to the top of my sub box and I have it tied to the rear metal support beam with a zip tie. not super strong but it's enough to keep it from sliding all over
    yea thats what i was using. i found these wall hooks at walmart today, i hope this will keep the skrew from making back ward progress. It literally unskrews its self lol.
    modmonster2008 Complete Newbie
    luckily i was able to install these two brackets on and since my car is a hatchback it doesnt move, its being squished in between the brackets and the rear seats :D
    when i had one, it was ziptied to the rear strut bar.
    Idk
    Idk if zip ties would do it. It slides laterally and even vertically. Over bumps u hear it, yet its drilled into the metal frame. Also the problem i keep having is that i can't get a nut in, to keep the skrew from coming loose through stop and goes. The bendable brackets i was using, decided to bend on their own, and they also have no rigidity anymore. And the L brackets I used have nearly no anchor points in the back.
    Its just a pet peeve i know. :sad:
    SaberJ2X Lurk MOAR
    Mayawest, PR
    you can cure the jumping with a bigger n heavier one :D
    um, i can't really help you. maybe build a new box to fit the trunk better?
    Phan Well-Known Member
    Orange County, CA
    i don't, just get urself some 100 RMS speakers and dynamats and ur finish. your corollas don't need trunk rattling woofers, its just weird.
    EliteRolla Well-Known Member
    Mesa AZ
    93 Rolla, 96 4Runner
    why dont you just put a bolt threw the inside of the box threw the floor of the trunk ... youll just need a long enough bolt to go threw both and a deep socket to get the nut on
    I was going to go for a speaker set up initially, but i got a great deal on the sub. I am very happy with it so far and my only complaint are the rattles that come from the glove box and my coins in the storage box :)
    I always wanted something a bit deeper for those certain songs lol.
    Rincon , Puerto Rico
    Thats what I used the L clamp and they hold good :)
    its_ikon FIRST widebody
    Henderson, NV
    try velcro
    DeebsTundra Big Tires :)
    Near VoRtEx
    Drill into the floor. Just watch out for your gas tank. 2-3 L-brackets on either side screwed into the floor will hold it perfectly fine.
    slow_rolla New Member
    2000 Toyota Corolla CE
    Idk if you have yet to solve the problem, but I have massive 5 cubic foot birch wood box with a single 15 running 1600 watts rms. I had the same problem you did with the movement and jumping. So I went to Lowes and bought 2 L brackets, 4 1 and a half inch self tapping screws and and 4 1 and a half inch drywall screws. I put them in on the inside of the trunk with the back seats down so no on could see them and they have held great ever since. I predrilled the holes in the box to avoid any possible splitting. My low bass hits way harder now that the box isn't moving and the setup looks a lot cleaner. If you want later I could upload photos? It was really easy to do even with my amp rack in the way.
    Really old thread and none of these members post anymore, and most of them don't even have a Corolla anymore, but go ahead and make a post about all your stuff, I'd like to see it lol
    progressbeyond likes this.
    So I just checked the date they posted after you said that.... lol noob problems
