Engine How do I take off the engine cover?
Discussion in 'Powertrain' started by nikeair11, May 18, 2004.
    nikeair11 Guest
    I want to paint the engine cover. All I need to do is remove the nut next to the VVT-I logo as well as the oil cap, and it should come off, right?
    Also, would brake paint be okay for painting it?
    oddfish Guest
    There are 2 nuts and 2 plastic push-in tabs. Just undo the nuts and pry up the tabs with a flat head (do it gently they break easily) and lift the valve cover off, the oil cap can stay.
    Sasuke Guest
    yeah gently on the plastic tabs because i did it and lift it up fast and its broken now gotta go back to toyota get some new ones
    Drummer426 Guest
    I have the same color car and i painted my engine cover with some High temp paint found at walmart. It was a dupli-color metallic blue. It looks pretty good. I just cleaned it with simple green. washed it off. primed it with some plastic primer and did 3 coats.
    www.cardomain.com/id/anthonyl go to page 2 to see my corolla :lol:
    Bolt Guest
    Yeah I broke both of my plastic clips when I first took the engine cover off. I was really pissed off. Toyota charged me $1.50 each for replacements (90467-06202).
    rolla_dink Guest
    even if you do break them, you can replace them with real bolts and nuts. Your local auto parts store will have some that fit perfectly. Just bring in the existing nuts and bolt. that's what I did to my cover when I had it and painted it.
    MrDisco99 Guest
    Thanks for that part number. I need a replacement myself.
    nikeair11 Guest
    Well, I finally finished. I guess painting isn't my forte but we all learn eventually. It's a little rough, but hey, I tried.
    SSJ_Rolla Guest
    yours looks pretty good
    mine didnt come out so hot..... but I tried hehe
    RexPelagi VDub
    Canton, Ohio.
    Both of them look good to me, nice job.
    SSJ_Rolla Guest
    Thanks,
    I just got to do some re-sanding or I will get it to match the exterior of the car
    AWC429 Guest
    thanks yall this really helpded i got bolts to rplace the plastic pins and i painted my cover red with plastic spraypaint. i dint have to prime the cover evn thanks a lot
