Hotchkis springs........HELP...
Discussion in 'Stop, Drop & Roll' started by kangkangmax, Jul 15, 2004.
    kangkangmax Guest
    i just got my hotchkis springs today. should the item comes with 4 springs and "4 black things"???
    pkpss Guest
    From what I recall, yes.
    kangkangmax Guest
    i only got three........... shit
    lonelydriver New Member
    call whoever sold you the springs and tell them you're missing pieces. they should send you the missing piece
    White Rabbit Guest
    LMAO those little black things are the bump stops or bushings..... You can also just use your stock bump stops and just cut them to match the size of the new one.
    CorollaAltis New Member
    i have 4 but 2 is different size so i juss use the stock bumpstops and cut it 1". its fine
    White Rabbit Guest
    Yep thats what I had to do after realizing i but the bumpstops for the rears in the front, I ended up having the small ones left for the back, being very lazy and pissed I decided to just cut the stock ones.
