Homemade Black Housing Headlights
Discussion in 'Exterior' started by DeathPool, Aug 21, 2006.
    DeathPool Guest
    I know that there are people out there making their own black housing headlights by painting them and I must say, they look real good. I tried this today and I got the headlights out but I couldnt get the clear front off, its glued down. Can anyone offer some DIY help? I know that atleast one of you guys have done this before.
    SaberJ2X Lurk MOAR
    Mayawest, PR
    it's on the DIY section or search for vamp, and then you go to his DIY
    it's something like putting your headlight in the oven at like 350~370'f for like 4 or 6 minutes
    SD_S New Member
    SF, CA
    you can either use the heat gun or the oven method you open your headlights. I just use heat gun and a flat head screw driver to open mines.
    charlee0621 Guest
    No actually you can use a heat gun to soften the glue around the housing to remove lens and heat the housing again after you reinstall the lens to set the glue again.
    alby13 New Member
    some people cut the lense with a dremel to get it clean and then reseal them where they were cut.
    the goal is to make it look as good as possible.
    Yeah, I have on accident. I was trying to remove the stock corner and I pulled in a certain way that the seal broke and the outer lens peeled/cracked off. It doesn't take much to separate them. Heat would make it even easier.
    Just pulled it and it came off? Sounds really interesting! Any pic? I wanna blackout mine. :D
    jdmikey New Member
    yea. my stock one's did that. i guess they were getting old. when i went to install my clears the outer lens came off in my hands. now i want to black out my clears but i dont know how to open them without a dremel. maybe an exacto knife?
    jdmikey New Member
    it sounds easy enough.
    i want to try to blackout my corners also. those might be a pain. anyone ever open them without using a dremel?
    Try a heat gun with an exacto knife.
    Rincon , Puerto Rico
    some people put it in the oven......if you go to corollacarclub.com they will help you out there cause i know asian rick did his on his camry ....
    The oven trick is risky and can damage the headlight. I say use a localized heat source instead.
