Engine !!hole In Intake!!
Discussion in 'Powertrain' started by corollin, Mar 10, 2005.
    corollin Guest
    !!hole In Intake!!
    There is a hole in my 92 corolla's intake. It looks factory. There aren't any vacuum lines around the hole that might look as if they were there. Need help and fast. The car runs normally. The hole is above the filter towards the driver.
    Thanx, The coroller
    is it the stock airbox?
    93rollaracer Guest
    my best guess is AIT sensor.. but it depends if you car is MAP or MAF
    corollin Guest
    yes the stock air box
    corollin Guest
    I used electrical tape and my gas mileage significantly suffered( wasted 1/2 a tank in 30 miles or so)
    yeah...i have a feeling you should have left it uncovered.
    corollin Guest
    I took the tape off and the gas mileage was much better
    ChristianVA New Member
    well put the tape back on.
    corollin Guest
    <a href="http://img.photobucket.com/albums/v288/stnnapunjabi/image4.bmp" target="_blank">http://img.photobucket.com/albums/v...jabi/image4.bmp</a><br />
    picture of the intake hole i couldn't get a better picture than this because it was tight.
    follow the harness from your distributor, should be taped together with another harness with a plastic plug like thing just hanging there.. someone prolly pulled it out and forgot to plug it back in.
    intake air temp sensor. you should plug it or find that temp sensor. your bypassing your airfilter and prolly you might suck something you might not like.
    besides that the AIT sensor help the ecu judge how much fuel to send, colder temp = less fuel, warmer = more. Your fuel economy would either be suffering, or your engine is leaned out.
    corollin Guest
    Where and how would i get the ati sensor and to install it on to what. I have no clue. Where the ati sensor would connect on the engine.
    PSyChO cHilD Guest
    Duct tape, super glue, chain, nabisco shredded wheat, 2 pieces of tin foil and 3 stamps. LOL
    I'm just messing with you man! Just do some electrial tape and you will be okeydokey.
    Silver_Nitrate New Member
    It's your temp sensor, you should see somehwere on your engine compartment either hanging or loose, its a small cone shape plug. All you need is find that and plug it snug and you're good to go.
    corollin Guest
    Thanx For All The Help Guys Really Helpful
